dubsential
- Joined
- May 31, 2016
- Messages
- 91
- Points
- 33
Hi, as title mk2 punto 2002 jtd..
Car was getting difficult to get into gear at times but not for a long period of time.. Except reverse which was always problematic. It cut out one day in the middle of the road due to another engine issue.
In a desperate attempt to move it I limped it a v short distance with the starter motor, in gear to get it out of the road however now it has no movement when in gear, you can move it in and out of gear without the clutch while running but it makes a racquet clattering without moving...
The starter isn't stuck that works fine
I dropped the oil out of the box with no nasty surprises.
It was squealing like the auxiliary belt was lose for a while but it doesn't seem to be, after awhile this would cease, wondering if it is the throwout bearing that was doing this and is the problem hence difficult to get in gear, however..
What is likely to stop the car moving while gears are engaged I assume only the clutch.. Anyone any ideas?
