TheAutopsy
- Joined
- Sep 12, 2017
- Messages
- 73
- Points
- 82
Hi guys, I bring you some questions about my punto GT. Im chasing some vaccum lines and some "improvements".
I have serveral questions.
1st- I have a manual boost controler, and I have the pierburg valve electricaly connected but I also have a vaccum pipe going to the intake. Should It be connected?
2nd- I did the "free turbo mod" from the old punto sport forum, where the boost controler is conected to the intake to help bleed the air quicker from the intercooling piping.
I went after this.
But there was some debate about where to connect the intake side. What confuses me is this statement "There are 4 points direct off the inlet you can use either of the two on the right hand side aslong as you T them in someplace else."
I did this, is it ok?
I used a T on the lower vacum port of the intake that goes to the fuel rail.
3rd - Im thinking about replacing the original recirculating valve, its 27 years old and I keep getting an open circuit error.
I was thinking about intalling a blow off valve, this type
But the original is this thing
Where do I connect the new one? On the intake pipe that goes to the turbo or on this pipe (the one Im grabing on the pic)?
I hope I made the questions clear enough. Any help is apreciated.
I went after this.
