Technical punto gt brake upgrade
Re: I've fitted Punto GT callipers/disc's!
Well its on my list of things to do when my A levels are over. :)
Went to the factors with a caliper to get the right pads today and after opening four boxes we came across the correct ones, the calipers are Girling but it's Lucas pads which fit in them! Very baffling indeed.
Liam
I would recommend that anyone sourcing calipers should get one pad too so they can take that easier into the factors rather than the caliper.
It's no use trying to describe the shape cos there is 3 different pads with lugs on the ends but they are all different.
Liam
Since your are adopting the Uno turbo caliper you are basically changing the whole front setup so yes caliper, discs and pads all for an Uno Turbo.
I have spacers which could be machined to fit this set up.
Liam
i've a spare pair of uno turbo calipers, although arc does have first refusal on them, i'll be fitting my setup after re-moting the car as at mo fronts are fine for mot so dont want to upset stuff for mot :p
:eek: How much you want for them? If arc doesn't want them I'll have them straight away :p I'm fed up with my crappy brakes and want to sort them out ASAP.
right a bit advice for peeps doing this.
if your rear shoes are worn then replace these at the same time.it seems from my (nightmare)experience that you need the rears tight on the drum to provide resistence to fully blled the system.
in my case i had a snapped brake pipe so you may get away with it if just swapping calipers but if oyu cant bleed the system then look to the rears.
i have just got the set up ready to fit to my sei front and rear do i need sei s/s hoses or punto gt hoses
Plummo80 said:
i understand that you need the gt hubs to fit the callipers and discs
No you do not remove the hubs to fit brake calipers on the front, you retain the Cinq/Sei ones.
And the brake pipes fit but always a worth while investment in s/s ones plus renew all fluid, then bleed brakes in sequence to ensure to air and new fluid all round.
Aaron.
