I ended up P clipping the fuel pipe under the rear seat panel. Those bendy clips didn't give me a lot of confidence.
JAN_5832 by Peter Thompson, on FlickrGood idea, which I will nick in the future....nice mod.
And before someone says it I know the fuses aren't lined up but they will be
If anyone else has a cable pull bonnet release instead of the lever can you tell me how its attached to the body?
On the end of the cable by the loop there is rubber bit that sits, inside the car, into the hole in the firewall, so when the cable is pulled tight on the latch it just sits in place and doesn't move and prevents the cable itself from rubbing on the bodywork.
Thanks Tony. You haven't got a photo have you? That's how I thought it went but it doesn't look right or secure
Anyone who has a carpet fitted but hasn't got the L centre console, how did you fit it around handbrake, gearstick etc?
