Technical Problems with direction lights ducato 1.9D
Ybosch
Good afternoon everyone, the handle for the direction L/R lights is blocked when the steering wheel is facing straight forward. The switching cams which are mounted underneath the steering wheel is positioned straight above the tumblers that popup when the direction handlebar is used and prevent them (actually one of the two, depending on the chosen direction)reaching their position. If I use the lever/handlebar for my directionlights it veers back. Is it possible to move/turn/adjust the ring of witch the switching cams are part of?
