Hmmm , i'm sorry
@Communicator , but i'm gonna have to beg to differ , with that statement , as there is on mine . Now i will admit it's a motorhome , so it's possible it could have been added , but i don't think so . I found it by accident while trying to source an issue with my front fogs . Both of these had packed up , but i also found a broken wire lying next to the battery . It was while tracing this wire that it led me back under the dash to the relay cluster . Further tracing led me over to the fog light switches , though the one i was following did go to the rear fog , not the front . I had two relay's , identical and next to each other to choose from . I concluded this broken wire was likely an earth for the front fog so earthed it out , and the front fogs instantly illuminated . I'm still puzzled as to why they led the earth , from the dash to the engine bay , but i can tell you , it ent now .
This followed on from a fault i had previously had with my wiper park not working . To my mind , the most likely reason , would be a faulty relay , yet the circuit diagram didn't show one . Long story short i did find one , on the firewall in the engine compartment , and since then , i've come to not trust the wiring schematics too closely , as they only show major parts .
Now as this is a imported German conversion , i will concede this could be a modification , but i really don't think so . The switch is standard , and the rear fog wiring appears included in the loom . The front fog wiring is not so here it is possibly an added circuit . Thirdly , the relay , and holder are the same type and make as those for the headlight are , which are highly likely to be standard .
However a 21w bulb only draws around 2 amps , which really doesn't warrant a relay , but my van has two , actually during conversion for use in this country it acquired a third , but i won't go into that .
Even at 4 amps , it still quite low power , yet there is a relay .
Okay so where is the relay cluster , It's behind the lower dash panel , on the passenger side . Take the lower passenger panel off , and you should see your relay bank right in front of you , directly below the fuse box .
I'm gonna try something here ; fingers crossed
Yes . Okay , well over on the far right side , about mid way up , you should see two small black boxes , with circuit patterns on them . The left hand one is my actual rear fog relay , the other is my front fog relay . It may look a little confusing , because i marked the fog relays with decals for future reference , and the decal you can see is over the second relay (front fog) , but this was not the point of the photo , so its all at an angle .
I have identified the headlight relays , there are four black , easy to spot , as they are all grouped together .
Two dip , two main beam , and one i suspect of being the indicator relay . The power rating is the clue there , but there are several more i've yet to identify . I can't remember the ratings on the relays you're interested in , and i just closed my dash up . I think it's 20 amps , but can't swear to it . Oh and just in case you've not realised , my van is a left hooker .
