I have a 52 REG 1.2 8v Punto and about a month ago it overheated in slow moving traffic. I noticed it as smoke started coming from the engine.
I managed to get it to a garage who said it was the head gasket and quoted me £475 part and labour. I could not afford this so took it home and decided to do it myself with the help of my brother who recently change a HG on a Peugeot 405.
We git the Haynes manual out and did it by the book. I had the head skimmed and we bought a new HG set with new bolts. Fitted using the recommended toque etc.
We also replaced the water pump and thermostat
We bleed the cooling system as described in the manual
However the car is still running rougth and sometimes missfires as you drive it causing loss of power. It also seems to be getting rather hot and there is a weird bubbling sound coming from the heater matrix.
I guess there is still an air lock so tried bleeding again using the guide on the forum but still have no luck. There is still steam coming out of the exhaust but the water level still stays around the same.
Trouble is I dont want to run it too long in case I blow the HG
any ideas?
also would an airlock after the HG change cause the car to run rough?
any ideas?
