Technical Valve cover gasket leak
MarkoRantala
Padasjoki
If your Punto 188 has a problem with oil leaks from the valve cover gasket, this could be the solution. I bought the original one first and it still leaked because it wasn't tightened enough.
This new model is significantly thicker, and also fits well. The only thing is to be careful not to overtighten.
CORTECO 026246P
Model
Dynamic 60
Year
2004
Classic solution for older FIRE family units was to grind/file ("deck", skim) 4 "stops" around mounting holes.
They limit amount of gasket "compression". Originally from factory it's often not enough to seal ("pressure" is too weak).
After modification you will get more "squeeze". No need for RTV etc.
