NopeHi
I find the power steering on my Panda is very light with little feedback, is it possible to do the opposite of the city mode and reduce the amount of assistance?
Yep, just fit an old, worn out battery. You'll even get a nice red light to tell you it's in 'arm wrestler' mode.is it possible to do the opposite of the city mode and reduce the amount of assistance
I think your only option would be to fit the steering column from a Panda 100HP. As far as I know pressing your City button would then give you the heavier steering that pressing Sport does on that car. I have the opposite on my 100HP (long story), meaning when Sport is pressed I get light steering and the increased throttle response. It shouldn’t work, but as my commute is in West London it just makes the car feel really light on its feet.Hi
The Delphi TRW system is used by a lot of manufactures and on a lot of models for decades. Millions of vehicles with few complaints for being over light.Hi
This is normal for EPS it’s the way it works. Any feedback is absorbed by the big damper of the electric motor.with little feedback,
There could be something wrong with your car. Either you have to drive another panda, ka, 500 or similar to compare or someone drive yours, I appreciate this is a matter of opinion
Sounds like somethings wrong.'I find the steering over light
If you mean vague I’d check the suspension arm rear bush. Very common.and a bit dead'.
There only a toe adjustment. How can they not succeed with several attempts. Unless something is worn in the suspension, after the local garage had several attempts without success
Uneven tyre wear after a garage has set the toe several times. How have we fixed this.I bought some tracking gauges, a couple of 3 meter straight edges, laser pointers and angle gauges and set it up myself, this has completely cured the uneven tyre wear on the car
Self centring is controlled via the electric motor and torque/angle sensorand it drives straight and true hands off the wheel,
It’s not zero at 40 but is negligible. Even pulling the fuse you will still have the motor acting as a damperit also handles well given what it is. I don't expect it to be up to the same standard of more exotic cars I have owned or my current weekend toy but had thought a little less assistance might enhance the 'feel'. I will try pulling the fuse to see how that changes things but if as you say the assistance is zero after 40mph I am not hopeful. In spite of this I have no intention of changing the car.
HiHi
The tyres are almost new but that could be a consideration when they need to be changed.I swapped all 5 155 80 13 tyres for 175 70 13 at 12 miles old on mine.
This size even fits in the spare wheel well, but it will raise the boot carpet about 10mm.
I have now had this size on for 13 Years / 130 K miles.
The width of the tread on the ground goes up from 105 mm to 135 mm.
In my Diesel this cuts the understeer a lot.
Worth doing.
Thanks, Ailurus Lapis
