jim whitehead
Hi there; where would I find the power steering relay
Thanks in advance
Jim
Thanks in advance
Jim
Mk2 have 2 relays on the end of the PAS Motor (These can be replaced with the motor taken out), Mk2/B have a Relayless PAS. Apart from that there is just a fuse in the main fusebox.
It's a mk2 2000 plate. Start car and power steering warning light comes on intermittently I am wondering if the relay is corroded?
Yeah all indicators going double speed ?
It could be anything
Could be low battery
No speed sensor response
Torque sensor open circuit
ECU dead
motor could be shorting out
Lots and lots of reasons
Since its free and v. easy to eliminate battery
Go to halfords and ask for a free battery check
if the battery comes back as been low on charge (a recharge should cure it)
Or battery under performing.... then replace it
The P/S on punto's are very very picky about voltage, they like a good strong healthy supply, a weak battery after cranking throws a low voltage code, PS shuts down to prevent notchy steering
Ziggy
Just a Note - you cant interchange the motors
mk2 Relay motor Cant go in a Mk2b Relay-less setup
You need ECU too i believe - but still not sure if that'd cure the issue 100%
Ziggy
Good to knoweven if you get pas ecu and steering column sensor it wont work on mk2b
have you tried a mk2 punto steelling column with the mk2b ecu and motor mk2b though
