General petrol flap repair?
felipefm
Nottingham
Hiya does anyone know how to put that back? I can't seem to do it... not sure if something is missing or just broken. can't find anything on ebay with that setup! thank so much
You have to manipulate the four spring ends into the four holes on the fixed bracket.
Would suggest get the lower two in the holes and then use tools/slotted screwdriver to push/flex the upper ones into the top holes.
Would probably be easier if you remove the bracket from the vehicle. (see the two bolt heads, which will have nuts behind)
There's nothing missing as far as I can see., but the lower end of the right hand spring in the pic could do with a slight re-shaping to make it straighter, it looks like it took a hit and has bent slightly over to the right (not by much)
Might be worth sending a message to someone like this
And asking how much
I reckon £20 would be what it worth online with postage
My local breakers would charge about £5 but they never have a panda in, when I wanted something
