Technical Panda 4x4 jack
doggydoctor
Does anyone know if the jack for the current panda 4x4 is the same as for the previous model panda 4x4
For the previous model (169) 4x4, Fiat used the same jack as the 'standard' car but supplied a 50mm thick plastic block to use with it (which was a bit wobbly!). For the newer (post 2012) Panda, the 4x4 is supplied with a jack that is bigger than that used on the regular models -marked as being for the Panda 4x4 and Qubo models only. Given that the newer car is rather heavier than the old 169 model, perhaps best to use the correct jack.
(Conversely, in case you were asking the other way round, yes, you could lift an older 4x4 using the jack from the newer one)
Thanks for your answer.
It is to lift a new panda 4x4. My previous 2013 4x4 had a spare wheel and jack. My new 2019 waze 4x4 has a repair kit and I was looking at sourcing a jack and space saver spare wheel.i found a toolkit that is said to be for the 2007-2010 doblo and panda 4x4.
The sticker on the jack states doblo and panda 4x4.
