posh pandas
wow, how do you know all this stuff
if you do think theres a chance though i'm up for having a go !
posh pandas said:wow, how do you know all this stuffif you do think theres a chance though i'm up for having a go !
If you're popping down ARC i can pass you that inlet manifold you were after a while back, and since your car is off the road now might be the perfect time to give it a shot.arc said:manchester isnt too far away, so i may pop up to lend a hand if you want.
There's a chance that the 1108 4x4 has the same system, but considering the owner is Italian i think there is a good chance he'll want to hang onto them just incase he nips back to see the relatives.christopher watson said:the headlights from posh might not fit, as your car has the headlamp beam adjuster inside the car (electric switch), which means you cant adjust the headlamps manually (behind the headlight).
posh pandas said:hi, manchesters too far for me as well while i should be at work....but if you guys are changing over the headlights i will swap with posh as i really hope to get him to spain in the next 2 months.posh's are for england as hes been here a couple of years.i will travel up to do this , just cant make the 12th .
best wishes with the engine change...gina XXX
Organising is a strong word for itpanda valdisere said:Well done Alan for organising the renovation on the country club, its crazy just thinking about scraping such a cool little 4X4,and also the fact that it has sentimental value to the lad!
Alan.D said:Arc:- the more the merrier![]()
Alan.D said:We now have a singing Panda 4x4 country Club![]()
Engine went in yesterday and although it took a bit longer than thought (as it always seems to these days) it eventually fired up and was running well gearbox was working forwards & back so just needs an MOT.
I wish Andreas luck in getting it past.
I'll stick up a post of the days events.
