I bought a wee Panda 4x4 yesterday, 2014 car with 49.5k on the clock as I wanted a low mileage vehicle to last many many years. Visited the car twice, test drove twice (1 long drive, up to motorway speeds and lots of junctions, second one short after a couple of issues resolved), felt happy with it.
About 30 mins into the journey as pulling out onto a roundabout gently in second there was a bit of a juddering sensation, and bit of a knocking noise which seems to be coming from the rear diff area. I tested it with a few more roundabouts and it seemed to ease off so I continued with the journey home. It raised it's head again about 30 mins or so later, so I did a wee bit more experimenting to see when it happens.
It seems to happen predominantly when in the speed range of 10-20 mph. If pulling gently in gear at this speed it happens, if a bit more throttle applied it eases off. As coming to a stop it happens a little as you slow in gear under 20mph. If you dip the clutch and coast then as you drop to that speed range it really does knock a bit. Noise and feeling through the body.
It drives really well apart from this, although a slight bit more vibration noise above 70 compared to other vehicles I've seen (noise only, no sensation). On switch on all lights illuminate and go out incl ELD and EM light. No lights come on whilst driving nor when it is suffering the issue.
Any ideas? Common problem? I guess my gut says diff bearing or a prop connection, but thought I'd ask before I start poking about.
Thanks!
Thanks!
