A Annetto66 New member Joined Oct 26, 2014 Messages 6 Points 2 Feb 16, 2020 #1 What steel wheels with 15" rims will fit this car? It came with alloys but no good for off road use. It's got 14" steel ones off a 1.2 panda on at the moment with off road tyres. Any ideas- this could get technical
V varesecrazy Patron member Parked in the garage Written 10+ guides Written a review Joined Apr 27, 2011 Messages 36,998 Points 10,549 Location Near the M4 Feb 16, 2020 #2 Hi. Ok all pandas are 'Standard Fiat' 4 x 98 pcd You want the same.. but in 15" Stilo is probably your best bet.. as later cars Grande Bravo and Croma Were joint ventures with GM so used 4x100 Charlie
D DaveMcT Patron member Written a guide Joined Sep 14, 2009 Messages 20,105 Points 4,011 Feb 16, 2020 #3 Bigger wheels raise the gear ratio. Not ideal for a 4x4. You are better to use 14s as you'll have more choice of tyres with chunky treads.
Maybemaybenot Joined Dec 27, 2019 Messages 281 Points 150 Feb 16, 2020 #4 And will limit the profile tyre you can use. A lot of a Panda being good off road is tall narrow tyres.
OP OP A Annetto66 New member Joined Oct 26, 2014 Messages 6 Points 2 Feb 16, 2020 #5 Hi charlie. Thanks. 4x98 but what central bore do I look for and can u suggest suitable fiat wheels
OP OP A Annetto66 New member Joined Oct 26, 2014 Messages 6 Points 2 Feb 17, 2020 #6 varesecrazy said: Hi. Ok all pandas are 'Standard Fiat' 4 x 98 pcd You want the same.. but in 15" Stilo is probably your best bet.. as later cars Grande Bravo and Croma Were joint ventures with GM so used 4x100 Charlie Click to expand... Thanks Charlie.
V varesecrazy Patron member Parked in the garage Written 10+ guides Written a review Joined Apr 27, 2011 Messages 36,998 Points 10,549 Location Near the M4 Feb 17, 2020 #7 Annetto66 said: Thanks Charlie. Click to expand... You are welcome.. Ive never worked on a Stilo.. Do check they are 4 stud.. not 5 ( as it was FIATs attempt at 'cloneing a golf') Bravo-a + marea should work.. but they are OLD Stilos should be easy to find.. for pocket money Last edited: Feb 17, 2020
