Technical Panda 169 New Throttle Body question
ıstanbul
Greetings everyone, this will be a bit complicated explanation.
-Previous fault lamp, irregular operation, stalling.
I had problems.
I determined that the map and eccentric cable were broken and repaired them.
-I detected some vacuum leaks. I fixed it.
Despite these, I thought my idling was not very good. I don't trust iacv very much. When I disassembled it before to clean it, the plastic came off easily. It has worn out over the years.
-While I was investigating the first malfunction above, I also purchased the throttle body.
Now I decided to assemble it.
After installing it, the idling performance of the car increased significantly.
The vehicle started to reach idle speed much more easily and quickly.So yes, my problem was here and it was fixed. I experienced very positive developments. The time I have to wait for the car to idle while stopping, starting and maneuvering has decreased.
Problem;
  • I guess he didn't recognize the new throttle body correctly.
  • Sometimes the idle remains constant at 1400 rpm. (Too high) (I'm not talking about the automatic choke procedure)
  • In general, it stays healthy at 800 rpm.
  • Sometimes it is wavy like 800-500 -800-500rpm. It works.
But despite its choppy operation, it never knocks or tends to stall. So my vacuum circuit is very healthy.
The LPG circuit is a retrofitted circuit. When running on LPG, the rpm is currently around 1500. I need to go to the service to set this up. But the problems I am talking about now are the events that occur when the LPG system is turned off and the vehicle is started on gasoline.​
Question;
  • Is there any automatic identification procedure that I know of? Or is there?
-Remove the terminal - Reconnect after the new throttle body. (20 minutes no energy)
  • Also, when I disassembled the old TB, I observed that it was quite oily. There may be too much oil coming from the vapor recovery pipe.
A dropping injector will give a negative fuel trim at idle
We go round in circles
Because MES is missing the value we want for this car there is nothing stopping us from finding out if a dripping injector is likely within minuites
We have a working K line cable, use some different software
We have access to a working scantool, get them to look at the fuel trims at idle
But does the LPG system have a separate ECU? And can we access that via the car's OBD?
gr J
Lpg system has a separate ecu.
From injector timing to fuel quantity. It has parameters that allow you to adjust how much fuel you want to inject at what temperature.
Although LPG adjustment is not very difficult. If incorrect settings are made. It may cause heat damage to the valves.
That's why I don't intervene with LPG until the vehicle runs completely on gasoline.
I've never adjusted LPG before. But I want to master this subject in the future.
It has its own ecu socket and software. Settings can be made from the computer.
Updates
Nothing changes.
Today I reset the throttle adaptation.
I use the car only on gasoline. After resetting the symptoms changed.
It used to fluctuate directly, now it signals a smaller fluctuation at first.
Before the reset, idling was causing less malfunctions. Now it gives more malfunctions.
This data has no meaning to me.
My guess about this is this. Some of the parts I replaced had previously affected idling positively. Now that effect has disappeared.
Ltft, stft I still can't look.
My desire to check the cylinder gasket and valves is increasing.
I will remove the cylinder head in the coming weeks.
Do you have any recommendations for the timing belt tool?
Apart from this, I bought a communication device for LPG.
I can run tests where I can turn the LPG injectors off and on one by one. Nothing changed.
The LPG circuit determines its own map by looking at the map and injection time. In fact, in advanced settings, the user can view the table with fuel trims by looking at the ltft stft settings.
I don't know if I can use this data to detect malfunctions or perform tests, I have this in mind.
I just came from a long trip of 3000 kilometers (10 days). It was a touristic tour with an interval of 500 km.
The idle problem is still the same :) but there is no problem in normal movements.
There is no water loss in the vehicle. Oil reduction is at the level written in the user manual.
I will disassemble the engine in 10-15 days, I am very curious, I hope I can find something.
Did the seller recommend this as a circulation pump? However, the propeller structure seemed too small to me. Also, the fact that the propeller is metal means it can rust. I think the original is plastic.
Does anyone have a picture of the original pump?
Also, are there any other pieces that come to your mind?
My purchases.
-Rocker arm cover gasket
-engine gasket
-Water pump
-timing belt and timing bearing.
-liquid seal
-Exhaust manifold gasket
-Engine oil, antifreeze and pure water
The top cover and valves are adjusted to the millimeter by CNC. I will give this directly to a service that repairs the cover.
Graf are a top brand water pump.
Do not spin the water pump without it being lubricated with anti freeze.
Metal impeller better than plastic, no rust due to corrosion inhibitors in "antifreeze"
Did your dog enjoy road trip?
İts made the holiday, not us. :)
It is very difficult to find a place to stay or a restaurant to eat with a dog. This problem becomes even more serious in small cities.
I think we will stay in tents on our next trips.
The vehicle is having a little trouble fitting our belongings. This holiday has led me to take a step towards the roof rack.
Fiat 500 is a car that I like very much. Every time I see it, I wonder if I can adapt. Then I give up.
In my country, the rearview mirror must be visible. Loading of goods in this way is normally prohibited.
There aren't many people who practice this. They are not legally involved.
Side mirrors are sufficient in most cases. As a motorcycle user, I'm used to this. Still, I try not to turn it off.
Hi @koalar ,
had the same problem with my Seicento 178AXC (which uses the same kind of throttle body/kit).
I used a OBD scanner and selected the the throttle angle to be shown. By just gently opening and then closing the throttle by hand it became obvious, that the the throttle valve does not always come back to 0%. Sometimes it stayed at ~0.4%, but values in the range of 3% were also present.
Like here https://www.fiatforum.com/threads/idle-speed-questions.463428/post-4363704 adjusting the end-stop (in my case 1 turn to the left) fixed the problem and the car (even when warm) does return reliable to normal idle speed.
To set the end stop you need an E5 torx ("female" torx). When adjusting, proceed in small steps and check this again and again with the OBD tool. Once you have found the desired setting, fix the adjustment screw with some paint or glue.
Since the end-stop should actually be set correctly on the production side, please check whether you have the same symptoms (doesn't always close completely) with the OBD-Tool before changing the setting!
Hope that helps.
Hi @koalar ,
Hello, I have 2 throttles.
Both the old and new ones seem to be 0.3% open. Always 0.3%.
Since the air coming from the gas can be measured with the map sensor, it should not affect it too much. So at least the idle should stay high. Mine is wavy.
Fiat specifically states that you should not tamper with the throttle adjustment bolt.
I'm very confused about this.
Yes, maybe you have another problem here...
For me the idle speed didn't always return to normal. So, it did not get wavy it just stuck high for a while until it went down to normal. This got worse once the car warmed up. When I was troubleshooting, I gradually ruled out everything possible and, despite the instructions in the manual, I started setting the end stop. Which finally solved my problem permanently.
My guess here was the following: Since this throttle does not have a dedicated idle detection switch, the ECU can only determine whether the engine should idle, based on the throttle valve position. I assumed that the throttle valve was closed mechanically, but the position sensor did not provide a stable 0% value (from time to time). From my understanding the vacuum already should suck the throttle valve firmly when idling and thus close it completely (from a mechanical/physical point of view).
If you want to set the end stop, you can mark the current position so that you can find your way back there if in doubt.
But I agree with you, I would only adjust here if you have already ruled out all other failure options. Maybe give it a try using your old throttle.
The screw is set at factory and should never be altered
Adjusting the screw is not recommended
If the idle is fluctuating it can't be the screw
If the idle increases permanently all the time, fixing the cause, normally a leak between the cylinder head and the inlet manifold, would be a better cause of action
However there are exceptions, such as some has already messed with it
I went to exhaust emission measurement.
Values like this afr 15.5 are too high. (Poor mixture)
I still haven't been able to disassemble the car. During this period, I bought a new motorcycle. I had to take care of him.
