- Joined
- Sep 14, 2009
- Messages
- 19,492
- Points
- 3,294
I'm absolutely sure. The 169 stub axle brackets go straight up from the swing arm tube. The 500 axle flares out >20mm and you can see the gaps either side of the bottom weld. The IM Axles listing for 169 axle contains some 500 images adding to the confusion. My original thread shows the differences.are you sure, is it not just the camera angle, its being sold as a Panda axle for both disc and drum models but not 100hp
and has been for at least two years, quite a few have been sold
PANDA 169 rear axle rot and swap. | FIAT Panda (Mk3)
I have a 2004 panda 1.2 with a rotted rear axle ( spring cups). I have a chance to buy a 2009 Fiat 500 rear axle with minimal rust. They look identical, although i read the track is a few mm wider. Will it just bolt on? The 3 bolt plates are identical.
www.fiatforum.com
Flared wheel spindle bracket on 500 Axle
Below is the straight bracket on the 169 axle taken from our 2005 Dynamic. Folded top to the stub axle mounting face hides any downward view of the bracket bottom edge. 500 bracket has a plain cut edge top and it flares out, so you get to see the corner gaps.
By the way - you can probably see why I changed the axle.
