General Paint code
General Paint code
I've got the Torx so no probs that way, yes I've got paypal don't know how to send a private message on here yet and don't want to plaster my email out lol
Ignore the bright light, that's my flash on my fone, but that's the colour of my car :)
Don't mind the handles being with the sparkles as don't think you would notice tbh
I've already sent you a pm :)
Missed out NOT
I don't mind handles without sparkles....etc
Think it looks quite good but then I've not studied what arbath should be or not, but think it'll look even better when you got both grills the same colour, different colours don't work tbh
ImageUploadedByFIAT Forum1368902255.906524.jpgImageUploadedByFIAT Forum1368902269.764971.jpgImageUploadedByFIAT Forum1368902289.132853.jpgImageUploadedByFIAT Forum1368902303.398597.jpgImageUploadedByFIAT Forum1368902319.040789.jpgImageUploadedByFIAT Forum1368902331.910499.jpgImageUploadedByFIAT Forum1368902345.002534.jpg
It's the rear doors that you need the long driver for. Remember to push the bold all the way in when you've unscrewed it or the clamp won't release the lock/lockcover
Cheers Phil, looks fairly easy, and I've striped down engines in the past so should be fine with this lol
Yeah send it up with the handles lol
Am ok as long as there is a Haynes manual or something then its not too bad.
What's the symptoms?
Pmsl, my symptoms are pretty much the same as everybody else with the M32 gearbox. It's got knackered bearings in there. Hope yours is ok.
Your gear stick doesn't flick back in first and 3rd gear does it? Sometimes 5th as well.
No am good thanks, is that what its called and what happens to it? How do you stop that or does it just happen?
From all the research I've done the only way to stop it is, either you're a lucky sod, or change the bearing that sits on top of the sixth gear. It's a vauxhall box and its ****. Lol
It is used in many cars, corsa vxr, Zavira, bravo just to name a few.
Fiat are fully aware of the problems, but you're like me I think, out of warranty.
Thinking i would rather change the bearing every couple of years to be on safe side
Mines is a 57 plate with only 39500 miles but not sure if the bearings will be upgraded on mine if yours isn't done on a 09 plate :rolleyes: my days of rolling about under cars are way past me, and i just done a search bye a few hundred pounds is a rough price to replace 6th gear bearings and set the cruise control :confused:
