PatrickV
I have had several weeks of problems with P1121 accelerator pedal fault.
Issue : Stop start not available and then engine check light followed by limp home.
I have replaced the pedal, the gearbox earth cable. Nothing seemed to fix the issue, if any thing it got worse.
I then started checking through all the electrical connections.
The fault in the end was a loose connection within the smalle engine ecu plug. It was caused by the harness not being retained correctly by the zip tie.
I thought I'd post this as I really struggled to get this car fixed over several weeks and alot of work and some money.
Hope this helps someone.
