General P0235 - Turbo boost sensor A circuit Malfunction
STILO NEWBIE
Ok, Got my CAN OBD2 scan tool today, I bought it on ebay for less than £30. plug it in at lunch time, it shown the same code as the garage did, the different was they charged me £35 for 2mins job, so I know others already recommanded it, but trust me, it will be the best £30 you ever spent, it doesnt fix the problem , but help you to narrow the area to look for, not to mention your female workmate might think you actually know what you doing!!! (y)
Anyway, turbo boost sensor A circuit malfunction.........what is it mean? something wrong with the wire or what? I already changed the over boost valve, it didn't solve the problem, which is fine, I going to move it up next to the battery anyway, and for £40 for the part and couple hrs work, I dont think I waste my time and money, I know I dont need to replace it, but I was hoping it will fix my engine cut-off problem. (for ppl who dont know, my engine will cut off for 50 seconds or so everytime I hit 95mph at 5th or 80 at fourth then back to normal.) The interesting thing was, after I took the old over boost valve off from my car, I decide to take it apart and have a look, guess what? I found water inside~~ although the part wasn't faulty, but there are trace of water inside the valve, I dont think they get in from the valve's body, they went inside the valve via the pipe I suspect, I might be wrong, but it looks like it.
Anyway, cut the crxx, does anyone know what turbo boost sensor A circuit Malfunction means? what is the turbo boost sensor and where does it sit? please help~~~:worship:
OP
OP
S
STILO NEWBIE
Well, no reply, seem it is a new one to everyone then........:cry:
Ok, last friday, I thought: lets think basic, what I done? I clean my boost sensor valve connector (blue one) with some contact cleaner, took it our for a spin... went all the way up to 125mph without warning light or engine cut-out, YES!!! problem solved!!
Not quite, its come back this morning at around 110mph, :bang: well, next step, remove my remapped, not I what I want, but it is cheaper than take it to the dealer and let them look at it, I'll let you guys know how I getting on.
andona
my obd2 scanner showed same fault code as well, changed turbo boost valve and problem solved, must be the remap you have i'm afraid, as i know of two other stilo's with same fault that were fixed by new valve...(y)
OP
OP
S
STILO NEWBIE
I got a reply~~~ :slayer:
Changed the valve but problem remain, Thanks anyway, now talking to the people did my map, see how it goes!!:confused: The good thing is the car still useable, might be a good thing as I have been stick to the speed limit!!! (y)
Steely
Dislikeskeyboardwarriors
Depressive Doncaster
what was your outcome to this? and what reader did you buy from ebay? the ones i have tried wont read the jtd? :(
yup that one of mine you tried was CAN_BUS, If you can get that other one off of crazy dave thats just a standard OBD2 without canbus protocol.. worth a blast!
