Ok, not up on electrics, so the resistance check and the paperclip thing are alein to me!
Anyway, the fan does run when you apply power to it using a different source.
Can't see how the "switched earth" thing works either. Consider the facts that the fan sitch is mounted in the plastic body of the rad and that the fan itself is mounted in a plastic frame attatched to the rad. There is no common earth link between them, only the cables supplying the fan via the switch.
It must simply be a thermal switch which is normally open during cool running and closes when hot, making the circuit and starting the fan!
As i said earlier, from the connector at the top of the rad, there is 12v. From that connector, 1 wire runs direct to the fan, the other to the fan switch and from there to the fan. So again, there can be no earth to swith surely? I gratefully receive any information and help that can be given.
As a foot note, the cap does appear to be working as it should. Maybe yesterdays overspill after the heat soak, flush out any remaing Radweld, but i have ordered another, just in case.
Sorry to be so long winded in my replies, but i just need to understand and to get my info across!
Thanks for your help thus far!
