General Overheating problem - very slow fan
chrisbell4
I have an overheating problem. It could be because the radiator fan spins very slowly and weakly. Any ideas how to proceed to fix this? My first thought is to fit a new fan but is this the best first step? The other point is that it loses water quickly. I topped up the rad but after just a couple of short journeys of a few miles it was below minimum again.
Should I replace the fan and see how it goes? I just get the feeling there may be more to the problem than that. Any ideas or experience with this problem?
I would fix the leak first.
The fan is probably postponing disaster.
Thanks. There's water at the bottom of the radiator (outside it) after a run. I assumed it has come out through the top when it overheated but maybe there's an actual leak in the rad. I'll look into it.
You can easy fit a new/2ndand fan DIY cheap
Try Bleeding your sytem
Do a search on here2find out how...
Try the zillion diff stopleak stuff out there4leak first imo
Paul
