Hi again all some advice please.
My punto 1200 8valve is being a pain having read some of the advice on here i want to ask more please.
It is overheating and heater aint working so i have bled it many times and when i do i get steam from the heater bleed?? It does the usual throwing the water out the exspantion tank when running. I am not sure where the thermopstat is but assumed it was on the top hose which goes to the radiator. This hose feels empty when the exspation tankl is throwing water out.
Do you think it is the thermostat. ?? Having had nothing but problems with thjis car i think iot is cursed ha ha . any advice is appreciated
Thermostat is in an aluminium housing on side of the engine, just below the coil pack. New stats come with the housing.
Compression test advised. You may well have killed the head gasket.
Then, if it indicates a blown head gasket, find the cause. It'll either be a faulty thermostat (beware of unbranded ones), a knackered water pump, or a water leak (radiator, water rail or water rail O ring are prime candidates).
In future, please start your own thread -- it's easier to spot and you'll get more replies.
