i turned it by hand earlier no problem
I never knew that , I assume thats becaus the ecu thinks its faulty and goes into a fail safe mode with the fan![]()
but it comfirms the ECU is talking to the sensor
Since yes - it saying hang on no answer
it jumps into limp home
Ok guys I have found the cause of the problem, the fuse has blown!!
I guess I should have checked that first lol
Still seems weird that smoke would come from the fan motor just because the fuse has blown though
Anyway thank you all for the helpit is greatly appreciated!
EML has gone out now
thanks again for the help im glad its all sorted now![]()
Ok guys I have some more news on this matter
I changed the fuse today then took the car out and got it up to temperature, when i came home and let it idle until the fan should come on.
The temp gauge went over the normal position and the fan did not come on still, so i span it with my hand to check if it still span freely, and as I did so it came to life and started working. However when it was spinning I could see what looked like little sparks from inside the motor.
After it had cooled the car down it went off, and I left the car to start warming up again and see if it would come on by itself, but it didnt so I span it by hand again, except this time it didnt come on, it just produced more small sparks inside the motor (barely visible) and sounded like it was trying to draw more power from the engine. (the same sort of thing as when you have a big electrical load on in the car and it is pulsing at idle)
Now after this im fairly sure it has to be the fan motor, as the relay and switch must have been working ok for the fan to operate with a little help from me.
What do you guys think?![]()
yeah after i tried that i thought it probably wasnt the best idea
i bought a new fan and motor online about an hour ago lol should have thought to test one from the scrappy first :bang:
also i have heard about the relay in regards to the cooling fan but im unsure as to what it does? and what it looks like? are they easy to change if it needed changing?
