General  over heating problem
cremulator
right my problem is
car is fine going around the door the temp gauge is in the middle heater working perfect and as soon as i put my foot down the temp gauge rockets up and the heater go cold . soon as i slow down the temp goes to normal and the heater goes back to normal
any ideas?
that sounds weird. Air lock? theres a bleed screw on the hose between the stat housing and the bulkead if i remember correctly.
cheers for you advice
we bled the system and back flushed it no joy
so we replaced themostat (right mess on ) still over heating when above 2500 revs
i can only suspect that the water pump is faulty ?
on my other car audi if you look in the expansion talk you can see coolant coming in from the top pipe but my doblo no coolant is coming in from the top pipe
should there be a flow of coolant like my audi
other thing when engine is on and you try to bleed from either radiator or from bulk head water just trickles out but if engine off and under gravity it flows very fast
so my thinking is that the water pump has failed ?
anyone got any ideas
quite possible,
you're not losing coolant..??,
a Palio Diesel owner found similar with a cracked head..:(
not loosing any coolant what so ever
its had a test to see if any gases are getting into system and that was negative
engine oil normal colour
i had my timing belt and water pump changed from fiat about 2 months ago
its going into them on tuesday to see what is wrong
Out of interest..which engine..?
it does sound odd..!
Charlie
this is the 1.9 mjet
its at the dealers today £90 diagnostic fee :cry:
