Not what your thinking m8
I am building a home power supply for something i am inventing.
I have built the power supply, but it needs regulating...
At the moment it goes something like this.
230v mains into a step-down transformer.
Through a rectifier to get varying DC.
Smoothed with an electrolytic(sp?) capacitor.
Now i have a 16.89-16.93v DC output, which is already pretty smooth, but needs to be smoother and slightly lower voltage.
To get exacly what i need, i require 15v DC output capable of 6A. Which (hopefully) if my calculations are correct is 53w.
With regulators (as you probably know), you loose a bit of power, normally about 3v, i have seen a few which have low power loss (max 1.3v loss), which may be ok, but the largest i can find is only rated at 5A.
I have ordered one, which i am sure will work, but i'm betting will get slightly hot
and require a heatsink. Ideally i want a variable (normally by resistors i think?) to get one that will not get so hot (as its in a pretty small space) and adjustable to exactly 15v DC.
Daz
