Cinquecento Orkney Cinq
Hey folks,
One or two of you may know me from the 126 community. I've grabbed myself a cracking little Cinq that was owned by a retired gentleman for all but the last year of its life thus far. He seems to have averaged at least 2000 miles a year and faithfully taken it to a handful of Fiat garages in Surrey and the surrounding area. I spotted it on eBay and bought it from the second owner (semi-related I think) who had taken ownership when the first couldn't drive any more.
Picked it up in Cambridgeshire and drove it all the way back to where I currently live: the Orkney Islands off the top of Scotland! So much quieter than a 126, I'll give it that. Although strangely not as comfy. I do prefer the Cinq to the Sei, nice and boxy!
There are two 126s in Orkney, my watercooled and an aircooled on one of the smaller isles. Now there are two 'centos, the other is a Seicento which always parks in the same spot at Tesco. One day I decided to roll up next to it for comparison...
I have a few questions, which I'll highlight in orange. The first being are there any 'centos in Shetland? If not I may very well be the most northerly Cinq here in Orkney!
On the drive up the Cinq performed flawlessly, and I reluctantly had to bomb up the A9 faster than normal when there was massive diversion threatening me missing the ferry. It still made it. What a contrast to what it was probably used to, I covered about 700 miles bringing it up here!
The Essentials
Once back I set about giving it the basics:
an oil change (I'm glad I checked the oil shortly after buying the car before the long trip... it was too low, and presumably the wrong grade as the previous owner had left an empty 1L bottle in the boot)
air filter change, before and after
flooding...
The most concerning problem was a slushing liquid noise when I engaged first gear and drove off. I removed the seats and carpet to find the driver's side underlays completely soaked with water.
Dried it out and tried finding the source, to no avail. So for a couple of days I drove about with no carpet to see. Nothing. With the underlay dry, I put it back in, put the carpet back on and drove about for another few days. The theory being that once it rained I'd check the underlay again and see where it was coming from. The plan kinda worked, this is what I saw:
it looked like it came from the centre. But the centre underlay (thick black bits) were dry and looking under them I could see no way of it coming from there. I figured it was a red herring and that it only looked like that because perhaps my foot pressed the underlay into the puddle when I stepped into the car?
After researching leaks on this forum I removed everything again and decided to investigate the sunroof gutters. I'm quite surprised by the design, why don't the pipes coming from the sunroof go out of the car, rather than drain water into the sills? Is that asking for the sills to rust!
I couldn't remove the sunroof pane, so carefully poured water whilst the car was parked on a slope. All the pipes were fine, however the drain hole on the driver's side front was sealed... presumably by the car being hoisted there by a jack or a garage's lifting equipment.
Had to take a small screwdriver and mallet to it, hammering the screwdriver upwards into the drain hole to recreate the hole. Eventually I got the water to flow sufficiently at a rate not quite as fast as the other side, but fast enough that subsequent tests (and driving since) have proved it fine.
I took the opportunity to replace the underlay... perhaps a bit liberally :rolleyes: but the carpet still sits fine.
Finally I flushed the coolant which was very dirty. The expansion tank was filthy and yellowed, you couldn't see the level. After a good flush I refilled it and then when I flushed the system again the next lot of coolant came out 95% clean.
A few weeks later Tesco had Prestone coolant on clearance so I flushed it again, 97% clean.
Today I flushed it a final time, since I was replacing the expansion tank with a new one. When I flushed it this time it was pretty much clean despite the tank still being filthy.
The new tank isn't that see-through, but you can now just-about see the coolant level which is better than nothing. Plus it's clean. Here's a before and after:
Still to-do
The car seems in good shape and there's only three mechanical things left to consider:
  • Clunking from the rear
    Sounds like my bushes have gone. Probably more, since I sometimes notice one side of the car sits higher than the other.
  • Tapping from the engine
    Occurs on idle only when cold. Once warm you only hear it when the revs are slightly above idle but any lower or higher they disappear (so when warm I only hear it driving 30-40 in fifth for example). I read on here this is a common occurence on the 899cc engines. What do you recommend doing, is it urgent to replace/adjust the tappets or am I safe to accept it as a quirk of the engine?
  • The fuel gauge
    When I fill the car, the guage only goes up to about 35% on the dial. When the actual fuel gets to 35% and lower the gauge follows and goes down. The low fuel light doesn't seem to work. I've currently decided to fill up once the gauge sits just below the second last line, which so far is at least 350 miles in a tank. I'm guessing the float in the tank is stuck and can't float higher for some reason, but I can't get to it. Will probably ask a Fiat garage to sort that eventually.
So this post was an introduction and mechanical service, the next update will be cosmetic!
Xylaquin!!!!
I saw you last weekend!! (not content with having photographed your 126 outside Bayview last year!)
I was in Kirkwall last weekend and saw your Cinq from behind going up 'near' the Willows, near the Wellpark garden centre
I just saw it from behind- and mentioned it to an Alfa chum of mine who stays in Tankerness; he said he hadn't seen it but thought it must be unique on the island!
I've seen that Sei (which you've parked next to) in the Tesco carpark for a while; sort of abandoned near the delivery van parking- do you know the owner? There's something not quite right about the exhaust on that car, I've noticed!
I can't believe you've sourced a Cinq to keep up there; that's so exciting to me; we've got to meet up when I'm next up...
I am trying to source one myself for my monthly commute.
I can tell you- having just spent a week on Shetland; that I saw no Cinq's or Sei's at all!
JimP
I don't. I'm sure I spotted it a while back in Stromness, maybe it lives there. Given the P plate I imagine it's someone's first cheap car and they won't be bothered by that exhaust lol
I was going to say the Cinq's an odd choice to do A9 commutes in. But I've previously been doing my monthly trips in a 126, so fair play :D What do you currently drive?
I'm currently splitting the commute between my Alfa 146 (NOT 145) and my FIAT Coupé (NON turbo)
But I've become obsessed by doing it with the cheapest possible fuel cost! The Cinq' is something I've always fancied, and suddenly I can now really see an application for it.
I'd be driving a bit slower I think; not that there's any speeding on the A9 now, of course; to be kinder to the engine.
I'm holding out for the 1.1 preferably in Imola blue- but I'll have to see what comes around.
I'd love to see your stable. are you in Harray did you say?
JimP
I'd like to amend the above post; which I have been thinking about- and can't see a way to edit...
I don't see an application for a Cinq' as a serious long-term commuter car; that would be insane; they are nearly classics now; and it would be a travesty to drive-one-into-the-ground in any manner; let alone on the A9.
These shapes take years to mature in my mind; and the Cinq' has now landed in my 'most desired' list.
With enough preventative maintenance (I don't use a car on a daily basis) and with the right weather- I would be interested to see how it would do on that run.
I drive up about eight times a year...
I used my Cinq Sporting as a daily when i had a 80 mile round trip work commute. Put 50.000 miles on it over 3 years, only let me down once when the alternator seized. Finally changing it for a lower miles Sei when i got to 128.000 miles
It was also to keep the miles off my Alfa, regular maintenance is key with these old cars but they are so basic and easy to fix and everything seems to cost no more than £30.
[*]Clunking from the rear
Pretty common occurance. Doesn't get picked up at MOT as the bushes aren't parallel so in droop they tighten up. Powerflex if you don't want to be doing them regularly.
[*]Tapping from the engine
Drain oil. Change filter. Fill sump to level with Diesel. Run engine at fast idle till fully warm. Drain sump, change filter. Fill sump to level with correct grade oil.
[*]The fuel gauge
[/list]
Dead easy to get at the level indicator, it's under that diamond shaped plate under the rear seat. Less than a quarter of turn gets it out.
Really?! Fill it up with diesel fuel... you'll need to explain this one to me, that sounds crazy and dangerous.
Got a bigger problem at the moment:
The earth wire has snapped. Anyone know the part number?
It connects to the earth point between the expansion tank and battery, but also goes on to connect the battery. In the photo on the right you can see the earth point bridges the cable in the middle:
Diesel is a light oil with detergents added. At fast idle there is enough pressure to keep the bearings apart while forcing the cleaning effect through the oilways.
Just add earths. You can never have too many earths.
Sorry for the delay, figured I'd post once I have a bunch of things to show!
You must have nailed that grounding-bond, then?!
Yeah, got an earth wire from factors and carried on. However I found the earth wire is part number 7724113 and bought the Fiat part. Comparison between what I took out the engine bay and the new official wire:
I also replaced the rear wiper with one that I believe is OEM... or at least looks more OEM. Old one top, new one below:
The rear wiper arm doesn't swipe as far as I'd expect, even when the arm is in it's rest position (which seems by most photos to be an acute angle). I've fitted the new wiper arm so that it sits parallel.
My third and final item: the wheel trims which I washed, sanded, primer'd, painted and top-coated.
Before and After
Only one of the wheels was really bad, here's a comparison of it before and after. It's not perfect- but it'll do.
Hey Xylaquin-
you're certainly battering through the jobs!
I can't believe you got that result 'by hand' on those wheels!
It was certainly looking quite ace; when I tracked you down last week!! :)
(sorry; I was working in St Magnus 'next door', and went for a walk on a break)
Although I drove the Cinq across the UK when I bought it, October has been the first time I've done my monthly Orkney > Central Belt > Orkney trip in it. Since the drive back is during the day I decided to take a handful of shots of the trip.
Delivering a cargo (of doughnuts) from Braehead Shopping Centre in Renfrewshire
Up the A9
Whilst I refilled my tank in Brora I spotted a 126 in the garage showroom :eek: and it turns out it's not the only one in the village... the pub owner has a red one too. What are the chances.
At the John O'Groats signpost
Ha!
Like a mini-A9-126-road-trip! More pics like this!!
you've got me into a groove of A9-photography, Xylaquin!
I love that road; and I seem to photograph The Mound, every time I come up; I duplicated your exact shot in July this year!
Yes; Brora ALSO has a 126 round-the-back of Victoria Garage on the main street.
You can JUST see it as you approach the village coming South, on the right. Just after the Clynelish distillery turn off.
It's just a shell, but beige, if I remember correctly...! (in fact; you can see it on Google-maps; in Streetview)
