Cinquecento Orkney Cinq
Hey folks,
One or two of you may know me from the 126 community. I've grabbed myself a cracking little Cinq that was owned by a retired gentleman for all but the last year of its life thus far. He seems to have averaged at least 2000 miles a year and faithfully taken it to a handful of Fiat garages in Surrey and the surrounding area. I spotted it on eBay and bought it from the second owner (semi-related I think) who had taken ownership when the first couldn't drive any more.
Picked it up in Cambridgeshire and drove it all the way back to where I currently live: the Orkney Islands off the top of Scotland! So much quieter than a 126, I'll give it that. Although strangely not as comfy. I do prefer the Cinq to the Sei, nice and boxy!
There are two 126s in Orkney, my watercooled and an aircooled on one of the smaller isles. Now there are two 'centos, the other is a Seicento which always parks in the same spot at Tesco. One day I decided to roll up next to it for comparison...
I have a few questions, which I'll highlight in orange. The first being are there any 'centos in Shetland? If not I may very well be the most northerly Cinq here in Orkney!
On the drive up the Cinq performed flawlessly, and I reluctantly had to bomb up the A9 faster than normal when there was massive diversion threatening me missing the ferry. It still made it. What a contrast to what it was probably used to, I covered about 700 miles bringing it up here!
The Essentials
Once back I set about giving it the basics:
an oil change (I'm glad I checked the oil shortly after buying the car before the long trip... it was too low, and presumably the wrong grade as the previous owner had left an empty 1L bottle in the boot)
air filter change, before and after
flooding...
The most concerning problem was a slushing liquid noise when I engaged first gear and drove off. I removed the seats and carpet to find the driver's side underlays completely soaked with water.
Dried it out and tried finding the source, to no avail. So for a couple of days I drove about with no carpet to see. Nothing. With the underlay dry, I put it back in, put the carpet back on and drove about for another few days. The theory being that once it rained I'd check the underlay again and see where it was coming from. The plan kinda worked, this is what I saw:
it looked like it came from the centre. But the centre underlay (thick black bits) were dry and looking under them I could see no way of it coming from there. I figured it was a red herring and that it only looked like that because perhaps my foot pressed the underlay into the puddle when I stepped into the car?
After researching leaks on this forum I removed everything again and decided to investigate the sunroof gutters. I'm quite surprised by the design, why don't the pipes coming from the sunroof go out of the car, rather than drain water into the sills? Is that asking for the sills to rust!
I couldn't remove the sunroof pane, so carefully poured water whilst the car was parked on a slope. All the pipes were fine, however the drain hole on the driver's side front was sealed... presumably by the car being hoisted there by a jack or a garage's lifting equipment.
Had to take a small screwdriver and mallet to it, hammering the screwdriver upwards into the drain hole to recreate the hole. Eventually I got the water to flow sufficiently at a rate not quite as fast as the other side, but fast enough that subsequent tests (and driving since) have proved it fine.
I took the opportunity to replace the underlay... perhaps a bit liberally :rolleyes: but the carpet still sits fine.
Finally I flushed the coolant which was very dirty. The expansion tank was filthy and yellowed, you couldn't see the level. After a good flush I refilled it and then when I flushed the system again the next lot of coolant came out 95% clean.
A few weeks later Tesco had Prestone coolant on clearance so I flushed it again, 97% clean.
Today I flushed it a final time, since I was replacing the expansion tank with a new one. When I flushed it this time it was pretty much clean despite the tank still being filthy.
The new tank isn't that see-through, but you can now just-about see the coolant level which is better than nothing. Plus it's clean. Here's a before and after:
Still to-do
The car seems in good shape and there's only three mechanical things left to consider:
  • Clunking from the rear
    Sounds like my bushes have gone. Probably more, since I sometimes notice one side of the car sits higher than the other.
  • Tapping from the engine
    Occurs on idle only when cold. Once warm you only hear it when the revs are slightly above idle but any lower or higher they disappear (so when warm I only hear it driving 30-40 in fifth for example). I read on here this is a common occurence on the 899cc engines. What do you recommend doing, is it urgent to replace/adjust the tappets or am I safe to accept it as a quirk of the engine?
  • The fuel gauge
    When I fill the car, the guage only goes up to about 35% on the dial. When the actual fuel gets to 35% and lower the gauge follows and goes down. The low fuel light doesn't seem to work. I've currently decided to fill up once the gauge sits just below the second last line, which so far is at least 350 miles in a tank. I'm guessing the float in the tank is stuck and can't float higher for some reason, but I can't get to it. Will probably ask a Fiat garage to sort that eventually.
So this post was an introduction and mechanical service, the next update will be cosmetic!
Well since October the Cinq has had more work done...
  • 63k service
    Since the previous owner had always taken the Cinq to a FIAT dealer for service, I decided to carry on with this. Makes the service history look even better! Unfortunately the nearest one is 3 hours south of me in Inverness, so on my way back up the A9 I dropped it off and carried on the next half of the journey by bus. Returned a week later to go collect it.
  • Fixed leaking coolant
    The coolant would gradually go down over the course of a few days, so one day outside the local Lidl I had a good look and deducted it was leaking at the pump. Whilst in for its service I asked the garage to sort out a leak and inconveniently they diagnosed that the radiator was leaking too (which I'm still skeptical of but hey ho). The Cinq now has a brand new pump and rad.
  • Install PowerFlex bushes on the rear
    Got the garage to do this too. The clunking is largely gone now!
  • Rear brakes overhaul
    The rear brakes starting making noise. Had McConechys in Kirkwall look at it and had them fit new drums, cylinders and shoes. Whilst the Cinq was in there a certain forum member spotted it; I later met Mr Giacosa and had a mini Fiat rally in a car park :rolleyes:
  • New headlight bulbs
    Whilst down in the central belt for Christmas I noticed one of my lights was only working on full beam. Fuses were ok, so checked the bulb and although it didn't look bad, replacing it with a new set fixed it.
  • New front tyres
    I also noticed that my front tyres had suddenly lost most of their thread. So had to buy a pair if I wanted to pass my MOT which I'd booked over Christmas. Fitted 155/65 r13 to get a little more width. The rears are still on 145/70. Dante noticed they were manufactured in 2007... yet they still look fine, have plenty of tread and haven't deteriorated.
  • A spotless MOT
    Something I haven't had in a while! No advisories or minors. Flawless MOT on a Saturday morning before driving off up to the isles.
Forgot to take photos, a habit I'm trying to resolve this year!
Been an interesting year 2020...
Went to collect a discontinued IKEA product all the way down in Nottingham.
I do remember longing for cruise control on that journey, it strangely felt longer than the initial purchase journey.
I think I've got a tradition going now...
Mk2 Panda - IKEA single bed
Fiat 126 BIS - tumbledryer
Cinquecento - bookcase
Replaced the radio aerial, as I accidentally snapped the old one. Sourced an original style one from REGMOT in Poland.
Gave the cooling system a flush. Must be a pretty clean now with it's new pump and radiator a few months back and now a flush with new coolant. Heck it was to get new coolant again at the upcoming service. The temp gauge tends to sit at the mark below 90 when driving about.
Dropped off the car in Inverness for it's 72k service and returned to Orkney in the meantime (they had a 2 week waiting list at the time). Again I'm continuing the previous owner's habit of dealership/Fiat specialist servicing. Sticking to the official schedule, the transmission fluid got replaced, quite possibly for the first time! I should've asked for a before and after comparison ha.
Then lockdown began, the garage shut and the Scottish government clamped down on the ferries.
You're only allowed on the boat if you've got a valid reason- and they're doing well to be strict about it (for example, you need a letter proving your case for travel, even if it's a funeral you're attending). Personally I'm supportive of this measure, we've only had 8 cases up here.
I ended up borrowing a vehicle from some farmer friends... a 2.5 litre diesel Mitsubishi Warrior, which felt like an absolute tank compared to what I'm used to :p (only picture I have of it is one parked next to the 126... but you get the idea!)
Whilst dropping off work laptops to council staff around the island, I went up a driveway and turned round the hedge to discover this member of staff used to drive a Sei! It's sitting just outside their door feeling a bit neglected from the moss that's starting to form.
To get the Cinq back, I ended up using Shiply and got it delivered to the ferry terminal on the other side of the water. The ferry company drove it on and delivered it to me waiting on South Ronaldsay, I then drove it back up to the main island.
Now back in the more fuel efficient, freshly serviced door wedge, the only thing I've done since is replace the rusty wipers...
Mini they said..
lol, one of the main reasons I refer to pre-2000 Minis as "real" Minis.
Fiat themselves are making variants of the modern 500 that are HUGE, and still calling it a Fiat 500xyz... then again they do have a knack for reusing "500" as a model name (*cough* Cinquecento)
Small cars are a lost art these days.
Super Clean
Gave it a damn good wash/clay bar/polish/wax a few weeks ago. One thing I've noticed is the logo badges seem faded... or are they meant to be that shade?
Handbooks
I've also got two different editions of the owner handbook; the very first which is correct about the keys but has diagrams of the early 93 dash, and a later edition which mentioned different coloured keys but has the correct diagrams. Guess I'm in the grey area in between! I do actually prefer the interior and dash of the early 93...
Replaced clock bulb
Replaced the bulb in the clock which had died.
Repaired gear stick surround
Then noticed the gear stick surround plastic had come away. I couldn't find the part number for this, but it turns out supergluing it back together works just fine and it looks almost intact.
I'm currently back to my monthly trip to central belt Scotland, and decided to test out the timelapse function on my phone.
www.youtube.com/watch?v=P3faRpPlpgk
Normally I average 52mpg, but on trips like this I get 55mpg. However on this occasion I got a record 61mpg (400 miles in one tank)... since I didn't drive any differently from other times I've went on these trips I can only ascribe it to the Redex I used earlier in the week which I got on offer ?
Fuelly page
On Tuesday my clutch snapped, or so I thought. Turns out it was just the plastic pivot that connects the clutch pedal rod to the clutch cable.
Bought a new one for next day delivery and popped to Halfords to grab some split pins. When leaving there was a Cinq Sporting in the car park :eek:
Replacing the plastic bit (seemingly called a clutch quadrant, not sure why) is easy but a bit fidgety.
Done the 81k service a couple weeks ago.
Funny to think I've done the same amount of mileage in 1.5 years as it's previous owner did in like 10.
The front seats have always been particularly grubby, so I smothered in a can of car fabric cleaner, then took a liquid vacuum to them. Liquid vacuums are sooo satisfying, you can see the dirt getting sucked-up as you do it, and unlike the regular cans of fabric cleaner you get in car shops, this method was visibly doing the job as I went.
Attached is before and after. Not perfect, but certainly an improvement.
