M meinit New member Joined Apr 17, 2013 Messages 3 Points 2 May 8, 2016 #1 Hello every one, i would just like to ask if the oil pump on a 2 litre Scudo JTD can be replaced with out removing the engine? Thanks.
V varesecrazy Patron member Parked in the garage Written 10+ guides Written a review Joined Apr 27, 2011 Messages 36,914 Points 10,515 Location Near the M4 May 9, 2016 #2 meinit said: Hello every one, i would just like to ask if the oil pump on a 2 litre Scudo JTD can be replaced with out removing the engine? Thanks. Click to expand... Hi, not a job I've done, but you'll need to remove the sump pan obviously.., I seem to recall mention of the g-box / bellhousing fouling access to that side of sump pan:bang: I'd just jack-up the front and just run around the seam of sump seeing how far it extends, FYI , FIAT tend to use an RTV "Mastic" to BOND on the sump pans..can be WELL STUCK - no gasket paper Charlie
OP OP M meinit New member Joined Apr 17, 2013 Messages 3 Points 2 May 9, 2016 #3 Thanks charlie, i am most gratefull to you, ill have a look this coming week end Any one else know any thing?
