Technical Oil pressure light
Petrifyer
UK
Hi, I have an oil pressure light, trying to see if it is related to the below before taking it anywhere, tried looking for info/diagrams to get this info but no luck so hopefully someone can help me here if that's alright.
It has had an issue with the breather pipe years ago and I wonder if it could be this again, picture attached it looks like there might be a hole? The area is covered in oil but that may be from before.
Also, I think there is a cap missing on this nozzle (circled red), is that right and could it be related/what is it and can I get a new cap for it?
Oil level is fine, light stayed on for most of the rest of the drive yesterday, going off once briefly and then coming back on again. I think I can hear a hissing sound when the engine is on. Not turning it on again however.
Model
Panda Dynamic 1.2
Oil pressure switch is next to the oil filter, low front left if you are looking from the front of the car, not in your photos
Check if it's weeping, if it is, it's highly likely the switch just need replacing
If you have a multimeter
There's only one wire which should measure 5V disconnect, ignition on
between the end of the sensor with the connector removed and the engine block, it should measure close to zero ohms with the engine off and open circuit with the engine idling
Is this a problem of the light being on all the time, or glimmering or flashing? Did it start suddenly . Does it just take longer to go out. Can we assume it is full of oil? And that the oil is good?
As Varesacrazy has said its pretty oily, but I giuess its got quite a few miles under its belt. These things have a very crude oil breather system on the crank case and a lot of oil vapour (and water) comes out and up the breather pipe it goes bacl into the air intake and often causes problems wiht oiling the MAP sensor in the inlet manifold. In my experience they vary a lot we have 1 really clean one and one pretty oily one. Both are low milage. If the breather pipe comes adrift it sprays a fine mist over the area in question. There are 2 breather pipes attachd under th airbox the thin one (mysteriously known as the big breather pipe because its long) and a shorter fatter hose. The littlem one push fits onto a spiggot inder the airbox and the bogger one likewise bust should be clamped to its position. The clamp is nearly always removed early in life by lazy people.... This tends to lead to the oily mess and sometimes the pipe comes off and you get a lot of oil and smell in the cabin. These htings do not affect the oil light but I would clean that area up as it will improve in car air quality. I use carb cleaner and then wash carefully with the engine running. Dont soak the ECU and avoid electrics where possible. Shield things where you can as you go.
If removing the airbox I undo the engine end of the big pipe and remove it with the airbox. Be very gentle when removing the long thin pipe as its easy to break that spiggot.
The oil presure switch is fixed into the oil filter housing front of the engine and a damaged or broken wire is possible. It may be the sensor which is easily addressed.
A worn oil pump more often leads to flickering oil light at tickover.
Broken oil pickup tends to be flashing light on and off at all times and speeds.
Even a very worn engine should get enough oil pressure to turn the light off as the car gets going but may flash on changing gear if really bad.
The oil pressure sensor sounds most likely to be the cause. It does need to be resolved immediately for obvious resons.
Regarding the missing cap. Yes, as mentioned by Varesecrazy above, it's the take off point for monitoring fuel rail pressure and the cap simply keeps dirt from getting in so if you can find one from a scrap car or maybe on line it would be good to get one - in the meantime a bit of tape wrapped round it wouldn't hurt.
Now, the oil light behaving as it is. Does the engine sound any different to how it has before? For the oil pressure in the engine to be low enough for the light to come on it's likely that you'll hear the big ends knocking especially if you've been driving it around with the light on for any length of time. This would sound like a rapid knocking noise especially when the engine is pulling or if you give it a rev up when standing still. I think it's more likely to be a faulty pressure switch. It's beside the oil filter and easy enough to replace with a new one. Again, as Varesecrazy says above, check the switch for leaks as I've seen this often and, if so, a new switch will sort it.
Lots of good advice, as usual, from Panda Nut and koalar too. Our 1.2 Panda was leaking oil from the breather pipe and making a mess just like that. I put a jubilee type clip on it which solved the problem for a while but the pipe was old and brittle and putting the clip on it just caused it to split after a wee while. Bought a new pipe from Shop4parts and it's been fine ever since.
By the way Charlie, I've been meaning to ask for a while, Where does Varesecrazy come from? Sorry if that sounds "nosey" but I just can't resist asking as it's not a word that makes any sense to me.
Hes mad about Italy I believe. Rightly so I wish I could live there.
Thanks all this info is very helpful, @The Panda Nut the light is on on ignition and remains on when engine starts, it started mid-drive yesterday evening and remained on, except for one moment, until it got back home.
The oil pressure switch looks very very slick, @koalar I don't have a multimeter but I will get my hands on one thanks. Sounds like agreement about sensor being the issue.
@Pugglt Auld Jock in the seat I heard no difference at all and under the bonnet I may have heard a hissing noise but it was faint if at all. Certainly I will get a breather pipe as looking closer it is rather cracked.
Thanks very much!
Thanks very much!
You are welcome. Does sound like a sensor or sensor wire issue.
Thanks very much!
Sounding very like the switch I would guess.
And so say I. I used to go there when I worked for Firestone - Monza most memorably - but Mrs J and I have also had some memorable holidays around the lakes - Oh, and a most memorable visit to the Mille Miglia Museum just outside Brescia. I'd very happily live anywhere around there.
Can't be a broken wire, the light would not come on
Can't be an earth cable problem as that has the
opposite effect of switching the light off happens
If there's oil on the end of the switch, it needs changing anyway, they only go worse never better
It almost certainly the problem
Around £5-10 and if you live near a large town you can probably pick one up today
we can reassess the problem latter if needed
While your there check the bottom of the sump, a small dint can cause problem
It's probably a 21mm spanner size
I have 466545149 as the product code, ERA oil pressure switch, seems out of stock online but I'll keep looking. Good to know it is likely safe to drive however in case I need to pick one up.
I use the fiat number in Google search
55202374 oil switch
But the switch is used by almost all manufacturers
Ford
Suzuki
Seat
Citroen
And so on
Which gives a lot of options as to where to buy it
55202374 oil switch
Ford
Suzuki
Seat
Citroen
And so on
The Ford KA uses the Panda and 500 engine 😉
I always like to use shop4parts to double check what was actually fitted, using the FIAT part numbers
It's a generic part, easy to find
Any motor factors and most dealers should stock
It's fitted in
Alfa Romeo
145 (1994-2001)
1.4 ie inc TS, 1.6 inc ie / TS, 1.7 ie, 1.8 ie inc TS, 1.9 JTD / TD, 2.0 inc TS
146 (1994-2001)
1.4 ie inc TS, 1.6 inc ie / TS, 1.7 ie, 1.8 ie TS, 1.9 JTD / TD, 2.0 inc TS
147 (2001-10)
1.6 TS, 1.9 JTD / JTDM, 2.0 TS, 3.2 GTA
155 (1992-97)
1.6 TS, 1.7 TS, 1.8 TS, 1.9 TD, 2.0 TS / Turbo, 2.5 inc TD
156 (1997-2006)
1.6 TS, 1.8 TS, 1.9 JTD, 2.0 JTS / TS, 2.4 JTD, 2.5, 3.2 GTA
159 (2005-12)
1.8 TBi, 1.9 JTDM, 2.0 JTDM, 2.4 JTDM
164 (1990-97)
3.0
166 (1998-2007)
2.0 inc TS, 2.4 JTD, 2.5, 3.0, 3.2
33 (1990-94)
1.4 ie, 1.5 ie, 1.7 inc ie / 4x4, 1.8 TD
4C inc Spider (2013-20)
1.8
Brera (2006-11)
1.8 TBi, 2.0 JTDM, 2.4 JTDM
Giulietta (2010-20)
1.4 BiFuel / TB, 1.6 JTDM, 1.8 TBi, 2.0 JTDM
GT (2003-10)
GTV (1995-2005)
1.8, 2.0 JTS / TS, 3.0, 3.2
Mito (2008-18)
0.9, 1.3 Multijet, 1.4 inc BiFuel, TB & Turbo, 1.6 JTDM
Spider (1994-2011)
1.8 inc TBi, 2.0 JTS, JTDM & TS, 2.4 JTDM, 3.0, 3.2 inc JTS
Tonale (2022->)
1.6 VGT-D
Chevrolet
Aveo (2011-15)
1.3 D
Captiva (2011->)
2.2 D
Cruze (2010->)
2.0 CDi / TD
Orlando (2011->)
2.0 D
Citroen
Dispatch Mk1 (1995-2000)
1.6 / 1.6i
Nemo (2010->)
1.3 HDi
Relay Mk1 (2000-06)
2.8 HDi inc 4x4
Fiat
500 (2007->)
0.9, 1.2 inc LPG, 1.3 D Multijet, 1.4
500 C (2009->)
0.9, 1.2, 1.3 D Multijet, 1.4
500L (2012->)
0.9, 1.3 D Multijet, 1.4, 1.6 D Multijet
500X (2014->)
1.3 D Multijet, 1.4 inc 4x4 / LPG, 1.6 inc D Multijet, 2.0 D Multijet 4x4
Barchetta (1995-2005)
1.8
Brava (1995-2002)
1.2, 1.4, 1.6, 1.8, 1.9 D, JTD & TD
Bravo Mk1 (1995-2001)
1.2, 1.4, 1.6, 1.8 GT, 1.9 D, JTD & TD, 2.0 HGT
Bravo Mk2 (2007-14)
1.4 inc LPG, 1.6 D Multijet, 1.9 D Multijet, 2.0 D Multijet
Cinquecento (1991-99)
0.7, 0.7i, 0.9 inc ie, 1.1
Coupe (1993-2000)
1.8, 2.0 inc Turbo
Croma (1987-2011)
1900 Turbo D, 2000 inc ie & Turbo, 1.9 D Multijet / MJTD, 2.4 D Multijet
Doblo (2001->)
1.2, 1.3 D / JTD Multijet, 1.4, 1.6 inc D Multijet, 1.9 D / JTD inc Multijet, 2.0 D Multijet
Ducato (1994->)
1.9 D / TD inc CAT, 2.0 D Multijet
Elba (1992-96)
1.5
Fiorino (1988->)
1.3 D / JTD Multijet, 1.4 inc ie, 1.6 inc ie, 1.7 D / TD
Freemont (2011-15)
2.0 JTD
Grande Punto (2005->)
1.2, 1.3 D / JTD Multijet, 1.4, 1.6 D Multijet, 1.9 D Multijet
Idea (2004->)
1.2, 1.3 D Multijet, 1.4 inc LPG, 1.6 D Multijet, 1.9 JTD
Linea (2007->)
Marea (1996-2003)
1.2, 1.4, 1.6, 1.8, 1.9 JTD / TD, 2.0, 2.4 JTD / TD
Multipla (1999-2010)
1.6, 1.9 JTD
Palio (1996-2001)
1.7 TD
Panda (1986->)
1000 inc ie CAT / 4x4, 1100 inc 4x4, 650, 750, 900, 0.9 inc 4x4, 1.1, 1.2 inc LPG / 4x4, 1.3 D / JTD Multijet inc 4x4, 1.4
Punto (1994->)
0.9 inc BiFuel / Turbo, 1.1, 1.2 inc BiFuel, 1.3 D Multijet / JTD, 1.4 inc LPG, GT Turbo & BiFuel, 1.6, 1.7 D / TD, 1.8 HGT, 1.9 DS / JTD
Punto Evo (2009-12)
Qubo (2008->)
1.3 D Multijet, 1.4
Scudo (1996-2006)
1.6
Sedici (2006-14)
1.9 D Multijet inc 4x4, 2.0 D Multijet inc 4x4
Seicento (1997-2010)
0.9, 1.1
Siena (1996-2012)
1.3, 1.4 inc CAT, 1.6, 1.7 TD
Stilo (2001-08)
1.2, 1.4, 1.6, 1.8, 1.9 D inc Multijet / JTD, 2.4
Strada (1999->)
1.2, 1.3 D Multijet, 1.7 TD, 1.9 D / JTD
Talento (1989-94)
1.9 D
Tempra (1990-96)
1.4 ie, 1.6 inc ie, 1.8 ie, 1.9 D / TD, 2.0 ie inc 4x4
Tipo (1989->)
1.3 D, 1.4 inc ie & LPG, 1.6 inc D, ie & Multijet, 1.8 ie, 1.9 TD, 2.0 inc ie
Uno (1986-2006)
0.9, 1.0 inc ie, 1.1 inc ie, 1.3 SD, 1.4 inc TD & Turbo ie, 1.7 D
Ford
Ka (2008-16)
1.2, 1.3 TDCi
Peugeot
Bipper (2010->)
1.3 HDi
Boxer (1999-2009)
2.8 D / HDi inc 4x4
Expert (1996-2000)
1.6
Saab
9-3 (2004-15)
1.9 TiD / TTiD
9-5 (2010-12)
2.0 TiD
Seat
Ibiza (1984-93)
0.9, 1.2, 1.2i
Marbella (1986-98)
0.8, 0.9 inc CAT
Suzuki
Ignis Mk2 (2003->)
1.3 DDiS
Swift Mk3 (2005->)
1.3 DDiS
SX4 (2006->)
1.6 DDiS, 1.9 DDiS inc 4x4, 2.0 DDiS inc 4x4
Vitara (2015->)
1.6 DDiS
Wagon R+ (2003->)
1.3 DDiS
Vauxhall / Opel
Agila A (2003-08)
Z13DT
Agila B (2008-15)
Z13DTJ
Astra H Mk5 (2004-10)
Z13DTH, Z19DT, Z19DTH, Z19DTJ, Z19DTL
Astra J Mk6 inc GTC (2010-16)
A13DTE - Up to 2012
A20DTH, Y20DTJ, Z20DTJ - Up to 2011
A20DTR
Corsa & Combo C Mk3 (2001-11)
Y13DT, Z13DT, Z13DTJ
Corsa & Combo D Mk4 (2007-15)
Z13DTH, Z13DTJ
Insignia A Mk1 (2009-17)
A20DT, A20DTC, A20DTH,
A20DTJ, A20DTL, A20DTR
Meriva A Mk1 (2003-10)
Meriva B Mk2 (2010-17)
A13DTC, A13DTE
Signum (2003-08)
Z19DT, Z19DTH, Z19DTL
Tigra B Mk2 inc TwinTop (2004-10)
Z13DT
Vectra C Mk3 (2002-08)
Zafira B Mk2 inc Life (2005-15)
And many more
