novatron1_2
My 1.4 16V 2005 Punto has an oil leak. I think it is the cause of my clutch judder. If I hold the car on the hand brake and slip the clutch it seems to clean it enough for it to work fine for a short while before the juddering returns, which I think is caused by a coating of oil on the clutch.
The top of the engine is bone dry so the leak is definitely coming from the bottom. I took some pictures tonight and it also looks like it could be coming from the sump. If the sump was leaking could this get onto the clutch?
As you can see in the general pic the oil has spread all along the bottom of the gearbox as well, I've noticed the leak is getting worse as it now leaves a few drops of oil where I park at night.
https://onedrive.live.com/redir?res...authkey=!AP3TJ_LhNM6xpWM&v=3&ithint=photo,jpg
Sump join wet with oil:
https://onedrive.live.com/redir?res...authkey=!ALzkPM7PDtSbnMA&v=3&ithint=photo,jpg
General pic of leak:
https://onedrive.live.com/redir?res...authkey=!AJvxS5KrQTohGaY&v=3&ithint=photo,jpg
So is it the rear crankshaft seal or is the oil managing to get from the sump join to the clutch?
