AndyB2005
2005 Ducato based camper van, 2.3 TD engine and 5 speed manual box..
A year ago I posted about fitting new shockers on the front, and the near side drive shaft pulling out of the gearbox, dumping oil on the drive.
I followed the advice given, shoved the shaft back into the gearbox, and kept fingers crossed...
Well roll on a year and 4k miles, and I've noticed there is an oil leak from this area, and so I guess the oil seal is buggered.
My question is how to change the oil seal? Is it a straightforward job of pulling the drive shaft out again, and swapping the seal with the gearbox in place, or is it more involved? The Ducato E-learn manual is not being very helpful (or I don't know what precisely to look for).
Many thanks,
Andy
Gear box oil all over drive on fitting new shock absorbers | FIAT Ducato
Hello folks, 2005 Ducato based camper van, 2.3 TD engine and 5 speed manual box. As per the title, I changed the front right hand shocker no problems, but on doing the LHS, I've pulled the drive shaft partially out of the gearbox, dumping a couple of litres of oil on the drive. Does the...
www.fiatforum.com
Many thanks,
Andy
