ivand
Could someone please tell me if these Lambda graphs are OK...
The car is Stilo 1.6.
(warming up):
(warm engine):
It seems that average cycle time is arround 1.39 seconds (between two maximum peaks), and that the graph is „lowered“ as if it's getting a lean mixture.
I am having problem with LTFT&STFT values, as they are high at 25-35%, and the car consumes above that it should.
I have removed problems due to misstiming belt, also checked and verified MAP readings, cleaned throttle body, cleaned injectors, replaced spark plugs, passed MOT with good lambda results:
....................@idle................@2800rpm
CO(%).............0,006................0,021
CO2(%)............15,64...............15,64
HC (ppm)............7......................9
O2 (%)..............0,250...............0,180
Lambda.............1,010...............1,007
Lastly I did some measurements with ECUScan, and got this:
O2 sensor pre-cat average value is about 0,41 volts (warming up);
O2 sensor pre-cat average value is about 0,361-0,401 volts (warm engine);
while O2 sensor after cat stays between 0,83-0,88 volts.
O2 sensor with ignition ON, engine OFF gives 0,014Volts.
Also I have checked resistance of O2 sensor heater, and it is about 14 ohms which seems good.
Somewhere I have read that O2 sensors can prematurely loose it's ability to perform best, giving results as there is lean mixture. Is it possible that lambda was damaged when one of the coils failed, and I drove car (on three cylinders) for about 10-15 miles to service?
Is it possible to clean this sensors?
Anybody ?
(warming up):
(warm engine):
Anybody ?
