Technical Novitec things...
AppleSei
RIP L181 VBB
West Yorks
According to a translator
Novitec Punto Bravo chassis feathers/springs limiter notice
the rest of it means
I offer here two new Endanschl? f?r the rear axle (in the sentence) from Novitec! These are suitable f?r the following motor vehicle types: * Fiat Seicento * Fiat Cinquecento * Fiat Bravo * Fiat Brava * Fiat Barchetta * Fiat Palio * Fiat Punto 1 (type 176) * Lancia Y the installation is very easy: They ben?en only a 10 mm of Steckschl?ssel! This Endanschl? are suitable f?r the assembly at the rear axle. After the assembly of this construction unit the remainder spring travel (depending upon motor vehicle type) is reduced over up to 25 mm!.
Pras83
Essex
These are 2 Suspension reducers for the rear suspension.
It says they will reduce the compression of the suspension by 25mm (depending on car model)
peaster2k
Prominent member
Washington, United Kingdo
Don't you mean they will allow the suspension to be compressed by 25mm more?
David
SkinzCinqSporting
MG ZR Owner :)
David
erm yes and no,NO seeing as they reduce the travel in the spring, so the suspension cannot be compressed by 25mm more in the sense of shock travel, therefore reducing shock movement, but YES because they compress the shock by 25mm, as in the top and bttom of the spring are pushed 25mm closer together. if you understand me?
Northampton
On a completely unrelated but slightly related note...anyone know of a UK dealer for Novitec?? I wouldn't mind a backbox, fancy something DTM style but don't want sportex.
SkinzCinqSporting
MG ZR Owner :)
www.forzatuning.com
EDIT: but search novitec exhaust in google searchin UK only for forza tuning's novitec stock, for some reason you cant view it from the main page
SkinzCinqSporting
MG ZR Owner :)
No probs, had a look and only stock novitec products for sei, if they have the exhaust you like it might fit, dont know if the exhausts on cinqs and seis have different mountings etc
Northampton
Looking at the Novitec site it appears that the backbox isn't SS. I might get a custom DTM styleee backbox in SS to go on my Janspeed/CSC system :cool:
SkinzCinqSporting
MG ZR Owner :)
Fair enough apple, personally I want a Cinq specific exhaust when I can afford it, I was kind of thinking out loud!
Oldschool
Banned
On da way 2 a new mission
www.forzatuning.com
Forza Tuning/ Autodelta or whatever they call themselves was sacked by Novitec.
The official importer/distributor is L&M International.
@ the ebay post - the bumpstops do not compress the springs.
