All 903cc/899cc pushrod Cinqs tend to have noisy tappets at the best of times, at worst they sound like tractors. You could try using fully synthetic oil, this may help. I'm sure someone mentioned that Mobil 1 do a good synthetic oil.
Welcome to the noisey tappet club, I tried the 10w40 semi synthetic stuff, made the noise worse, I'm using 15w50 mineral oil at the moment and it has made an improvement, you could also try adusting the tappets if you have an early cinq(part manual/part hydraulic) or get the rocker shaft assembly from the later model with better full hydraulic tappets....
i payed a garage to sort them out (on the old cinq) - it just started again a month later.... if you want to ajust them yourself your gonna have to keep doing it reguarly otherwise just put up with it
