Panda (Mk3)  Newbie hello and Panda error code question
Taffodils
Hi all, so pleased to have found this forum!
We have a 2004 Panda 1.1 Active which we adore.
Yesterday I replaced the indicator/wiper switch gear as the full beam switch had broken and whilst it was a successful job, we now get some error codes appearing on the dashboard if you touch the light stalk after the ignition is switched off.
The headlights come on (even if you remove the key from the ignition) and the code ‘f3’ appears. If you continue to push the light stalk the code changes to ‘f6’ and then in increments of 3 all the way up to ‘f21’.
I suspect that a simple reset is required as to change the indicator/wiper switch I had to disconnect the battery and remove the airbag.
I am sure someone here will know the solution but I can’t find the answer despite searching!
Hi A3jeroen!
You are absolutely correct! Thank you!
I did of bit of digging around and found some instructions on how to set/deactivate the ‘Follow me home’ function and I’m pleased to say the car is now all good.
Thank you for such a speedy reply.
Cheers! ?
