YesTo je drugačije od onoga što nam je prvobitno rečeno
Is this correctThere is no voltage at the connectors of the two coils.
I have voltage to the coil connector..it lasts as long as the fuel pump works..Je li ovo točno
Smeđa i crvena žica trebaju biti napon akumulatora pri uključenom paljenju.
Can we answer the question correctlyI have voltage to the coil connector..it lasts as long as the fuel pump works.
It's not minus when you put 200 amps through the earth lead, at cranking, there's a voltage drop due to the resistance of the cableafter your suggestions on what to do by measuring and testing I determined: 1. the voltage on the coil lasts as long as the fuel pump works. 2. the oil light goes out. 3. the alternator and engine lights come on. 4. how to measure the voltage between the minus pole of the battery and the engine.. the engine is already in minus. There must be a language barrier.. Will it be clearer now.. thanks
It's best to measure between starter motor casing.regarding the minus pole voltage and the engine, I will check
That is good. Means ground cable is good. We have that checked.I've been charging the battery regularly, it's running very well, and I've been renewing the grounding on the engine and engine compartment, since I had a bad contact case on another car.
Sounds good to methe oil light goes out 3-4 times after trying to start the engine... there is no spark on both coils, on the 4th spark plug... regarding the minus pole voltage and the engine, I will check
A/C???And with multimeter on A/C probes between the two wires
Should be between 0.5 and 2.0 volts AC while cranking
Alternating current, a type of electrical current in which the current repeatedly changes directionA/C??
