General New radio
General New radio
julia11
I have the uconnect5 dab/sat-nav in my car. Since the uconnect app no longer works it's not that good. Are there any recommendations for a replacement please?
Tipo 2016 hatchback 1.6 diesel
Im in the same boat ( and same car) trying to figure out way to upgrade to uConnect 7. Aftermarket car play won’t work with all car settings as wiring loom for sat nav units is diferent that non sat nav. You may be left out with Chinese units with limited functionality.
I had a few options when the uconnect worked, it says it will start working when you login to stellantias but that's been 2 years so who knows
I'm confused the app did nothing other the tracking your journey's and shoe abbter level fuel level ect what are people missing from it?
I had the battery information, online music (a bit like Spotify) car diagnosis when there was a fault, that I have noticed, there were more options before it went offline
Hi @julia11 and @berlinasportiva. You are both hero's in my book for finding those replacement systems. I got my 2016 Fiat Tipo 1.4 T-jet estate last year and the DAB Ariel needing replaced and the stereo are the only things I need to get done this year. Please please let me know how you get on with it.
Hi, I had to replace my aerial as I had no dab working. Not too bad to do just don't rush it. It is not worth buying a second hand one, I did this first and it also was broken as it seems to be a generic fault.
Hi, I've heard it's a generic fault thought to be water damage. I planned to get a new one once the warmer weather comes.
This is what the base looks like when off the car. Might help when browsing part details
If you replace the serial
I recommend getting a tube of silicone grapes and covering ever joint under the aerial base with it to prevent water ingress
My current one has worked for 5 years now without issues
Not very related, but when I change the radio, do you think it would be possible to add a reverse camera? Don't currently have one
