New purchases....
New purchases....
I am desperate for a piece of information! I need to know exactly what amp will run my subs best, both are 300watt rms each and 4ohm each. I want an apm that will run 350watt rms each at 2 channels, what amp is best, i have a budget of £220 MAX, please quick accurate help would be great (y)
Chaos, where fore art thow?????????
Look at my very first post again Jordan ;)
Remember that Blaupunkt for 180 quid? I'd go for that :)
As you have single voice coil (SVC) 4 ohm subs, you can wire them in parallel so that the overall impedance is 2 ohm. You want a mono amp, not a 2 channel (y)
That Blaupunkt will give 1 x 650WRMS @ 2 ohm while the subs will take a total of 600WRMS....................................;) You also have 30 ish quid left over (after paying for P&P as well) so you can spend it on nice thick cabling :D Or some Guinness, whatever you prefer :p
I'm sure there's other amps out there, but it's a case of having a look around :) You want a mono amp that will do 650 - 700W RMS (ish) at 2 ohm. That will be fine (y)
HTH
Took me AGES to find this again :p - hope someone replies lol! I have waited that long for the amp that i eventually cancelled it, they are having problems gettting that particular model apprarantely, but i was browsing and found this, do you think it work work well? just a quick reminder that im running two SVC 300RMS subs at 4ohm each on a mono amp making them see 2ohms, and this amp is 900 watt rms at 2ohm. anybody rate them?
http://www.caraudiodirect.co.uk/product_info.php?products_id=4172&cadid=90b2f11b003734e8790a9a213dcdbe95
chaos or paulfbd you've both been a great help btw ;)
Jordan
Jordan
Should be fine :) Bit of headroom is always good ;) Just don't go mad with the gain first off :)
Thanks pal (y) I shall look forward to posting about my builds next, im moulding the 2 12's into a weird kinda shape but maintaining the required volume behind each in a cool way, not polystyrene balls like i have done in the past but somethign else :)
Dont worry wont go mad on gain, let them bed in first til they're nice and soft, thanks chaos (y)
Jordan
