My cars to low, need a solution
S
Steffan
I have 40mm lowering springs, 17"low profile tyres and the rieger kit, i now have to plan my journey inadvance because i have to be sure there are no speed bumps or sharp inclines.
it's not fun.
it looks gorgoues low but i need the option to go higher.
has any1 got a coilover suspension kit, is it easy to adjust the ride height on these.
i've looked in to hydraulics and air suspension, air would be the best for me. any 1 one got experience of it, can i get a control inside and bounce down the road to my big dogs take that?
yours faithfully
Steffan
got the same prob... im getting hydrolics hopefully
Smee
Re: Re: My cars to low, need a solution
Out of curiosity, how much would one set you back, (the hydraulic or air suspension)
"Here's to alcohol - the cause of, and solution to, all of life's problems."
Re: Re: Re: My cars to low, need a solution
hydrolics is about £1500 no sure if thats fitted tho.... air bags r cheapers but u get a diff ride style...
Smee
Re: Re: Re: Re: My cars to low, need a solution
With coil-overs its easy to adjust the ride height, but you have to jack each wheel up to adjust it...can be a pain...
Daz
Re: Re: Re: Re: Re: My cars to low, need a solution
how much can you agjust them? (the coiloveovers)
about 1500 including fitting but hydraulics take up more boot space. takes about a week to do.
Stef
Re: Re: Re: Re: Re: Re: My cars to low, need a solution
but looks the ******... slammed when parked. nice ride hieght and then wait speed bump... push of a button and ur over
Smee
Re: Re: Re: Re: Re: Re: Re: My cars to low, need a solution
only problem is you gotta suck your bank managers dick for a set of them.
Re: Re: Re: Re: Re: Re: Re: Re: Re: My cars to low, need a solution
Usually coilovers adjust from 20-80mm...
Daz
my cars to low
steffan
had the same problem DEMON TWEEKS fitted spring
assister`s "rubber ring"still bottoms out over speed
bump`s.
E
1K
E
P
15
12K
Dark Lurker
A
570
A
3
7K
Steve
S
