Barchetta My 1995 Fiat Barchetta aka Claudia
This is my 1995 Fiat Barchetta 1.8L 1747cc L4 designed by Andreas Zapatinas and Alessandro Cavazza with such a good taste and sense of a car's lines.
She's almost 17 years old but still going strong due to some careful owners until now! I am not sure about the previous owners but I do my best to keep it in top shape!
I hope you will enjoy my Claudia! She always puts a smile onto my face :)
  • Like
Reactions: maverick1508
at idle at 3000 the engine revs itelf without me giving anymore gas. indeed it revs faster. i have been talking to mr fix it and he recomended going back to stock asap. the weld does not look best. i do not like this also very much. i prefer a stock working variator. if that weld brakes loose and metal goes into the engine will not be good...
Hi Stanca, I broke a set of H&R 25mm lower springs but still have my Eibach going strong:D
If your thinking coilovers then KW are good.
Eibach 30mm lower springs on Bilstein B6 shocks are an excellent set up for the B although I may change to the B8 shortened damper and get a lowering coil adapted. This would give me the perfect setup . (y)
The H&R hubcentric spacers or adaptors are great though.
Hiya! Stanca,
Depends on how low you want to go.
The Eibach springs are progressively wound too. but only do a 30mm lower spring height.
These are what I have but I would like to see my B sit a little lower, especially on the front.
Only before I could do this I would need to modify and raise my internal wheel arches as the new Brembo set up along with the 17" wheels offset is just touching slightly on full lock.
Think the H+R springs come as 25mm lower or 50mm
I would definitely recommend the Eibach's (y)
Some updates in photos. ;)
