Looks well cared for and waxed. Is that the original PVC hood?
True. It's always waxed
, most of the times with Carnauba wax.
The hood is PVC OEM in honest shape! Not so happy with how the back side rubber seal falls onto the body but this is what I call "character"
Also on the character list are next items
- in heavy rain water builds up where the hood should lay when folded
today I had to remove the plastic panels surrounding the hood bay so they can get dry since right now they are soaked
- a little rattle when I turn the engine on! Myeaa, the variator gives signs
but is still in working shape.
I sometimes test the variator. My way of doing it: Neutral Gear. Easily give gas until around 2500-3000rpm, point where I keep the pedal still and if the variator still does the job the engine should rev itself from that point on! And it does! :yum:
- back bumper paint is slightly chipped. I guess previous owner had some "rear action" :devil: at some point and just can sprayed it for sale!
- right side upper shock bearing gone! Needs replacing soon! For now just took it off, dismantled it, filled it with grease to stop the knocking and put it back as a fast temporary fix
- radiator leak inside the cockpit, driver side, temporary fixed with some "stop leak" special "sand" ! Just for now, I know is not recommended to keep that into the cooling system for too long.
- some minor bodywork paint chips here and there, nothing obvious
- right hand side window doesn't step on the PVC hood as it should and I get wind noise at high speed. I suppose a hardtop will fix this for good
- airbag light is on in the dash after I took the seats out for upholstery replacing! I cleaned the wire couplings with electro-cleaner but still is on! I am not sure if I should just put the engine tester on the B and fix the fault
- and the latest :idea: the wipers stopped working! When I put them on, I can hear the relay going "clanck!" but the wipers don't move...
With all this i still LOVE HER
PS: Since forum space is precious this thread will be the only place where I will post anything that happens to this beauty
