They sure have been cut deep, maybe that could be the reason they were getting so hot?
That is some wear isn't it. At first glance you could be forgiven for thinking they had been cut differently. Is this the first time you have the valves out of this particular head?
The inlet seat simply dropped out probably because of high temperature; it was easy to tap back into place but seems firm enough that it would probably have stayed there. If I had better access I might have been able to repair well enough by the roadside to hobble home; there is nothing actually wrong with the inlets.its really strange that its the inlet one which went, as its the exhaust seats which look over cut to me.
Check your pulley and see if it's coming into contact with the engine mount. If not sure, fit some spacer washers under the engine mount and see if the clunk goes away.
The stabiliser should prevent any backwards and forwards movement of the gearbox mounting bracket. With all that extra torque when you change gear etc the engine/gearbox must move a good 5mm![]()
I doubt it. I would imagine that it was done for cost. Probably a case of let's stick a bigger engine in, to keep them happy until we release the 126.
