No. Twin air has no inlet camshaft. Its all hydro- electronic computer supervised valve actuation. Clever, astonishingly effective and muderously expensive if it goes wrong. But quite a lot of fun. My TA is coming up to 30kmilez so hopefully still a youngster
Just thought I'd jump in here because I'm very interested in variable valve geometry setups. There have been quite a number of attempts at this over the years and some designs have employed valves actuated by hydraulics and/or electronics completely independent of mechanical linkage to the crankshaft in any way. There's many advantages in being able to control valve opening and closing in this way but it's an expensive way of doing it so, as far as I know, it's never made it's way into a mass produced road going engine?
That notwithstanding, I got very excited when Honda decided to turn their VTEC engine design - which was heavily slanted towards producing power, and very successful at it it was too - towards maximising economy. They called this i-VTEC (Intelligent VTEC). Here's an excellent video which shows how it works:
Especially interesting is how it holds the inlets open long past BDC and keeps the throttle butterfly open fully when in it's economy operating mode, thus virtually eliminating, or at least substantially reducing pumping losses. I took several test drives in a Civic estate with this engine and very nearly bought one some years ago but had to ditch the idea when we found that the diminutive Mrs J couldn't find a comfortable driving position where she could both see the slightly strangely positioned digital speedo and be able to fully depress the clutch pedal. I liked the car a lot and really regret not buying one.
Now though I have the FIAT Multiair system to interest me and I've been looking at it for some time now trying to understand exactly how it works and it's weaknesses, especially as the new Firefly Global Engine uses a version of it. It does have what at first glance looks like a conventional camshaft, but it only operates the exhaust valves directly. On the inlet side the cam lobes operate pumping plungers which compress the engine oil and shoots it down drillings to hydraulic cylinders above the inlet valves. Basically, when the cam depresses the pumping plunger oil is transferred to the cylinder above the relevant valve which then depresses the valve stem and causes the valve to open. What a complicated way to do it? But then you have to understand the "clever" bit. Half way between the pumping plunger and the cylinder above the valve there is an electronically controlled bleed off valve. If this valve is fully open when the pumping plunger is depressed by the cam lobe then the oil bleeds back into the engine without causing that inlet valve to open at all. If the bleed valve is closed all the oil ends up acting on the inlet valve which will be fully opened. Still sounds like a very complicated way to do what camshafts have been doing with valves for many years though? Well, the clever bit is that the electronics can independently open and close the oil system as it likes so bleeding off or not bleeding off oil in this small pressurized system as it likes thus exercising flexibility over when the valve opens and closed in a way no purely mechanical camshaft and follower design can. This allows even more flexibility than the more mechanical system the Honda used so allows even more control over reducing pumping losses, economy and power production - It's very, very clever. Here's a video which demonstrates the main principles:
When you throw in some VVT control then it all becomes super interesting.
Hope you enjoy the videos and can understand my description of how I think the systems work.
The Honda uses a hydraulically operated locking pin to lock the rocker arms together when in "high power" mode and, interestingly I found you could feel that locking in at around the 4,000 rpm mark on the ones I drove. If you kept it below that it was a very docile and driveable engine which I liked because you knew that driving at lower revs fuel consumption was being maximised. If you really needed it though the noticeable extra "punch" was there simply by hanging onto the gears for longer.
The FIAT system, because it has much greater control over valve operation, has considerably greater potential but, whereas the Honda has proved to be reliable and only uses the hydraulics to slide the locking pin on the rocker arms, the FIAT system is hydraulically depressing and releasing the plungers on every revolution of the cam. Think about how often, fast and violently a valve is being operated at even moderate engine revs and this system worries me. The control the system allows is however, indisputable. Using the correct engine oil is not only very important for the survival and long life of the mechanical parts of the system but also seems, from what folk on here who run them have posted, critical to the correct operation of the hydraulics. repairs to the hydraulic block seem to be cripplingly expensive and some parts are only available as a complete unit.
So. Considering whether I'd ever buy and run one? The conclusion I've reached so far is that I might buy a new one where I would be fully in control of ensuring all maintenance was rigorously carried out to schedule and all the correct lubricants and filters etc were used. Don't think I'd risk a used one no matter what it's service book looked like.
I'm looking forward now to reading posts from you folk who do run Multiairs and twinairs and telling me how good they are. As a parting shot. The girl who lives in the flats opposite us has a very trendy 500 Twinair. It's grey with a black roof and black trim including black alloys. She has just had it professionally valeted today and it looks a million dollars - all nice and shiny! However, it sounds absolutely terrible when she starts it up! sounds like everything is knocking and rattling away as if it's about to self destruct at any moment! - I don't know where she gets it serviced but would love to know!
