Yes I have buddy I’ve done the vehicle and bought the pack needed but they sent every colour 7 total leadsHello,
Go to multiecuscan.net, find the proper model / engine, you'll see the adapters you need to connect to the modules you want to connect to.
For the 2,0 - 2,3 - 3,0 diesel engines you need the following:
The green adapter is required for the 2,2 diesel.
I've bought a bluetooth interface STN1170 for FIAT and Ford and can connect to all modules. I've got also a KKL cable which I've bought years ago for my alfa. But it needs the colour adapter to connect to other modules.
I've read here that gendan is a reputable, very helpful seller. Could check with them, too.
Thanks yes mate I’ve been reading this tonightThe different OBD2 readers are used for the different type of buses/ protocols used on a vehicle eg J1850 LINBus CANBus and other protocols like KKL (originally VAG) different coloured adaptors are used to swap the pin configuration to connect to different module. The type of bus used is dependant on age eg a modern duke uses CANbus and a yellow adaptor.
this will guide to correct setup required
Yea looks that waySounds like you've bought a complete kit of software, VCIs and all possible adapters that allow you to connect to any vehicle that the software (MES) supports. You could have bought a licence for MES alone and sourced an appropriate VCI and adapter cable separately. If you have the vLinker MS VCI it works just like the CanTieCar multiplexer with the current version of MES, so you won't require any adapter cables whilst using it on an X250 or X290.
No I have a manual . @Fredastaire can you help with this matter. I see the need for speed NO the need for a guide.Have you used the mes to do the kiss point and clutch bleed
Thanks mate I’ll have a proper read when home just in traffic I have done the manual bleed in the same way you mentioned@Seanwinder22 @theoneandonly , I have a 2017 Ducato 130 with comfortmatic.
Earlier this year I changed the clutch fluid. First vacuumed out the round tank with a vacuum syringe kit. Second refilled with clean new brake fluid. Connected Vacuum syringe pipe to the bleed nipple of the slave cylinder, released the nipple , memory says circa 1/8 turn anticlock, syringed out dirty fluid, watching the reservoir level drop. Kept on topping up the reservoir as needed. Closed the bleed nipple and removed the kit supplied plastic pipe. Topped up the reservoir to circa 6mm from top. Carefully rotated the cap anticlock until I felt it drop on to the thread start then screwed clockwise carefully, it's not a good fit so be careful that you are screwing correct as cross threading is a risk.
Connect MES and select the calibration. The instructions are clearly written on the screen page. I think I had the MES ready to click, then started the engine and immediately 'clicked'.
It takes seconds to calibrate, you don't feel or hear anything. Stop engine and restart..
Please beware that I'm working from memory, just read the instructions and follow.
I was staggered with the smoothness after the calibration sequence. It was notchy before
I intend repeating early next year.
Please do let us know how you get on.
Read it all now@Seanwinder22 @theoneandonly , I have a 2017 Ducato 130 with comfortmatic.
It says what I posted mate in progress please wait and nothing happens so I don’t start the engine because it’s connectingIve not done this procedure but many others
Is it actually in progress or waiting to staRT EG press Y or click on Execute.
I have Victron software set up that monitors the starter and leisure battery even a trickle charger my battery is always sat at 12.6v alwaysSome posts matching "clutch calibration" that might be worth reading on the MES forum:
One, specifically related to the Ducato and clutch calibration dropping out without processing, resolved the issue after fitting a new vehicle battery.
I've never attempted this myself, but I assume the temperature requirements explained in the image taken by the OP were met? Some procedures won't run unless the specific conditions are met, or if they do, might not complete satisfactorily. And stage 2 as shown in the image does say "Start the engine" although more text may be obscured by the "In progress" overlay box on the screen.
When it says in progress, it means that the procedure has been activated. But it won't continue because it is waiting for you to follow the next step and start the engine. When it recognises that the engine is running, it should operate the clutch 5 times within 60 seconds, after which you should turn the engine off, wait at least 15 seconds and turn the key to MAR.It says what I posted mate in progress please wait and nothing happens so I don’t start the engine because it’s connecting
Yea your wrong sorryWhen it says in progress, it means that the procedure has been activated. But it won't continue because it is waiting for you to follow the next step and start the engine. When it recognises that the engine is running, it should operate the clutch 5 times within 60 seconds, after which you should turn the engine off, wait at least 15 seconds and turn the key to MAR.
I might be wrong, but I don't think the box is asking you to wait until it tells you to start the engine. It's tyelling you to wait for the function to complete, but it won't do that unless you follow the instructions on the right of the screen. I know it's not very intuitive, but I've seen similar instances that can probably been explained by the author's native language not being English. Start the engine anweay, It will either continue the activation or stop it and maybe give an error message. It won't do any harm other than not completing the calibration if it fails.
Before starting the procedure, select the engine and clutch temperature parameters in the Parameters screen of MES, and ensure that the temperatures exceed those required to complete the procedure successfully - engine temperature greater than 80C and gearbox between 20C and 150C according to the procedure for the Selespeed box I'm looking at in MES. There is no mention of driving the vehicle so presumably that's not required to complete the function for the Ducato box, although stated in instructions for different vehicles.
And yes, if you have any fault codes current or stored, this and any other procedure might refuse to run or not run correctly. It's always a good idea to fix and clear any codes before any programming functions are executed..
