Bernievarian
Prominent member
- Joined
- Jan 15, 2017
- Messages
- 2,993
- Points
- 715
Hello
Still not working
Some ebay link where I can buy ELM adapter for big point year 2007
http://www.ebay.co.uk/itm/162524569889
http://www.ebay.co.uk/itm/161715574389
and
http://www.ebay.co.uk/itm/271275445368
All worked for me. However as they offer free UK postage there is no international option. Try contacting them and see if they will ship to you.
Robert G8RPI.
Thanks my friend
Hola Julio,
between PIC version, Firmware version, PCB version, there is too many possible combinations that one cat wouldn't find her kittys... I really doubt ANY cloner would try to implement the very cheap CAN controler on a PIC chip, so once the "plug" is opened it's quite easy to follow the PCB tracks from the CAN pins to the chip (they're straight) and identify if there is a termination resistor (terminator ? ;-) or not. Some I/F come with an R-C network, which is fine, others don't even have that f** resistor which is fine as well.
But definitely, if one want to connect to other MCU than the engine and ABS (with the yellow plug) this resistor, if present, HAS TO BE REMOVED.
BTW, you'll never know what chip's inside before you open it (after buying, of cource)...
Buenas tardes, Bernie
Can only speak for my Bravo 1.6MJ but that does all the engine things including resetting the oil and service indicators. and using another wire does not work. Only Fiat would make cars operate so differently.
Having done the oil and air filters and oil, I understand why the service cost is so high...... Its over 40 years since I had so much trouble, needed so many tools and made so much mess. Well done Fiat for the staright forward common sense design your are a bunch of stars. (I dont't think!)
