The F/L muffler sits higher than the R/126 but I am wondering if the brackets that bolt to the block are interchangeable so that a system from one can be used on the other?
I have to agree with Peter---to the best of my knowledge, the brackets are not interchangeable. The exhaust 'down-pipe' shapes are slightly different; the 'Thermostat-housing' air outlet (into the car) are in different places, which is one reason why the exhausts are differentI don't think so; but I think the angle of the stud mounting in the block is also different, so maybe?. The 126 bracket is much heavier built. On balance I suspect you need to match the correct engine block, brackets and muffler.
Understood. I believe I have ended ordering an F/L muffler for my 126a block. Debating now what to do. Does anyone have a picture of the block of a F/L in this area? Here is how my muffler is currently sitting in relation to the studs.
Unfortunately, I ordered from the states and had delivered to Canada (expensive) paid duties and taxes etc and to ship it back and do it all over would probably nearly cost the exhaust all over.
Might still be the best option… I would still love to see a close-up pic of this area
The exhaust is an ANSA unit made for an F/LWait a minute...another fly in the ointment. Looking at your exhaust...it's the simpler, cylindrical version. I think one like that was fitted to some later 126 engines from Poland. You might be in modifying territory in any case.
It looks like the type made for the "N" and "D". It would obviously require yet a different set of exhaust brackets from the ones that I'm familiar with, even on an "F".The exhaust is an ANSA unit made for an F/L
That may end up being the way to go I agree. Would also mean that I would be have to start cutting up these brackets which would make going backwards impossibleIt looks like the type made for the "N" and "D". It would obviously require yet a different set of exhaust brackets from the ones that I'm familiar with, even on an "F".
I would dispense completely with the regular brackets and make some from flat,, mild-steel bar.Once aligned you could then have strengthening gussets welded on as with the standard brackets in order to give some rigidity.
Thanks.After a quick look, the shape of your muffler is significantly different then a stock 500 or 126 muffler. It seems to be a more sporty style "exhaust", whether or not it still uses the stock style brackets is a gamble. One suggestion. If you are willing and able to do some mild modifications. I would start by slotting the bolt holes in the stock bracket so that the bracket can slide up slightly. Then . Do a few passes of high temp exhaust wrap around the muffler where the clamps go. this should help support the muffler from below. even if the muffler doesnt fully fit the contour of the bracket. And heck, while in there, if you want to reduce engine bay temps. Wrap the exhaust manifold pipes with the exhaust wrap also. Will give it a sporty look and significantly cut down on engine bay temps.
