Hi there can anyone HELP me my car failed mot on the wish bone I have got all the pins out except for one the one that goes in the sub frame on the passenger side the thread is striped and cant get it out any body got any ideas ??
how did you strip that thread? i would first try to use plumbers wrench if bolt is already partially lose, if that wont work, then some bolt extractor, or weld a nut to it, or flat screwdriver and start hammering
strange for subframe bolt to seize not had one yet , took apart few puntos and everytime hardest bolts to undo were from seatbelts, not counting driveshaft nut
it will be the welded nut on subframe there are 2 ways to get to it drop subframe or cut a hole in floor with a holesaw the nut is a 22mm socket so cut a hole so socket will fit in pull carpet back if left side look for rubber plug in floor then about 100mm to right and down towards the panel sealer their is a bump the nut is under there
Hi problem solved thanks DAVE C owe u one that's saved taking sub frame off just drilled were u said then bingo it was there the weld had snapped of the nut
