the uneven tyre wear could well be because "Macpherson strut has slight movement at upper attachment. "
This would allow the steering and wheel alignment geometry to vary slightly as the vehicle was moving.
Otherwise, there are many causes tracking, tyre pressures, hard driving to name a few.
At the top of the strut is a roller bush in a rubberised mounting, this allows the strut to turn with the steering, this is where your slight movement is apparently..
It would need a new top to cure it, that means removing the strut assembly, compressing the spring, removing the top plate, replacing the top plate and refitting. Not too hard a job but you need some good spring compressors and a decent socket and spanner set. when you remove the hub from the lower part of the strut, tie it up so it doesn't hang on the brake flexy pipe. !
I would tend to leave it unless it is causing an issue, check tyre pressures first. for the strut to cause the tyre wear it would usually have to be fairly bad movement which would normally fail it...
