- Joined
- May 1, 2019
- Messages
- 754
- Points
- 241
Site will not allow prefix, a technical thread...
Hi Ben, it's working now...
I have the lads Punto for the weekend as there is a similar problem with the near side rear light unit, an intermitant suspected bad earth.
Again, just like the o/s/r light unit, there is an intermitant bad earth. This time, the narrow earth track has been drilled dead centre for the plastic hot rivet method of securing the earth track in place.
An extra earth wire soldered to the Light units main earth track at a suitable place, a bullet type connection for ease of light unit removal with the extra earth wire eyelet using the oe earthing point behind the trim panel.
If this fault " dash warning, check running lights" is happening to the lads Punto, 2010 Evo 1.2 8 valve, it is also happening to other punto's of a similar age.
If your rear lights are misbehaving with the odd symptoms of a bad earth, then consider an extra earth wire.
The near side light unit earth track is a particularly "bad design".....
